Rock,hard place front main bearing
#2308593
05/21/17 04:51 PM
05/21/17 04:51 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I have cross bolt mains 1,2,3,4,5 and I need to check #1 but the oil pump is in the way of the side bolt and factory steering box limits oil pump removal.I think I can drop the pump 1/2" to loosen the side bolt and then the main stud to check if the bearing is still tight after that.
Re: Rock,hard place front main bearing
[Re: Clanton]
#2308638
05/21/17 07:01 PM
05/21/17 07:01 PM
Posts: 7,480 Minnesota
Hemi_Joel
Minnesota
I have removed the oil pump before with the engine in the car. I can't remember the exact proscess, but I think I had to jack up the drivers side of the motor, and then back out the bolts but leave them in the pump.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: jlatessa]
#2309082
05/22/17 02:18 PM
05/22/17 02:18 PM
Clanton
northern,Ohio,USA
If I remember right, when I removed the pump to install a high volume kit , I removed the pump cover first, then the body and rotor and installed in the reverse order, didn't have to jack the engine.
Joe BINGO! I just did that,Thank you.Now I have a clear shot at it all.
[Re: Clanton]
#2309146
05/22/17 03:39 PM
05/22/17 03:39 PM
Clanton
northern,Ohio,USA
Well it is looking like I rolled an oil ring putting it together,The main,rod bearings look perfect[almost,lol] on #1main,rod.The squeak is coming from #1 it sounds like and I could pull that head but if you have an idea to test let me know.
[Re: Clanton]
#2309161
05/22/17 04:08 PM
05/22/17 04:08 PM
Posts: 2,296 NE Ohio
DoubleD
NE Ohio
I know some of you will say just pull the darn engine but I take this as a learning exercise,opportunity Yep a lesson in why you did not pull the engine! but I am guessing you already figured it would have been easier to do that. Doing an in line re-build should only be reserved for a big diesel engine or something that runs on NITRO
[Re: DoubleD]
#2309163
05/22/17 04:10 PM
05/22/17 04:10 PM
Clanton
northern,Ohio,USA
I know some of you will say just pull the darn engine but I take this as a learning exercise,opportunity Yep a lesson in why you did not pull the engine! but I am guessing you already figured it would have been easier to do that. Doing an in line re-build should only be reserved for a big diesel engine or something that runs on NITRO My choice and I can live with it.
[Re: Clanton]
#2309175
05/22/17 04:32 PM
05/22/17 04:32 PM
Clanton
northern,Ohio,USA
Well I need a line hone,the top half of the bearing is black on 2/3 of it on a 3/4 groove bearing and by the tab is ok.So now we know and thanks for listening.
[Re: Clanton]
#2309203
05/22/17 05:31 PM
05/22/17 05:31 PM
Clanton
northern,Ohio,USA
There is a high spot at the oil hole and a mark on the back of the bearing from the raised spot so I am sure the others are like that.I had the same issue with the cam bearings!!!!!
[Re: Clanton]
#2309206
05/22/17 05:37 PM
05/22/17 05:37 PM
Posts: 2,175 Duloc
The Shadow
Duloc
