New member - Building Mopar powered '41 Chevy streetrod #2308853
05/22/17 12:06 AM
05/22/17 12:06 AM
VA
41MoChev Offline OP
41MoChev  Offline OP
VA
Hello fellow Mopar fans,
I'm building a '41 Chevy street rod and will be building a Mopar LA engine and 727 transmission to put in it. I'v e always loved Mopars, especially '60s - early '70s so when a co-worker offered me a 360 block I got it. Did some research and learned about the 408 stroker kits. Scored some 340x heads and a six-pack manifold. I recently came across a deal on a 340 block and picked that up. It turned out that the 340 block is "virgin"; it is a '71 casting and has never had a piston in it. Apparently, it was a spare parts or replacement block from the '70s that a dealer had squirreled away. The cylinders have never been honed and according to my measurements with a non-calibrated micrometer, the bore is just under 4.04". If I go with the stock bore on the 340 and stroke it to 4" it will be a 408 or I could bore it and get up to 416. I'm thinking the 8 extra cubes are not really worth unnecessarily boring a good 340 block. I'm not looking to build a race car, just a reliable driver street rod with loads of torque and a good highway cruiser. Opinions welcome. Advice will be considered.
Building '41 Chevy street rod with Mopar LA power. I tell my Chevy buddies it's on the Chevrolet improvement Program.
Re: New member - Building Mopar powered '41 Chevy streetrod [Re: 41MoChev] #2308898
05/22/17 02:14 AM
05/22/17 02:14 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I'm sure it won't take long before someone offers you a complete engine for that block. Good luck with your project
Re: New member - Building Mopar powered '41 Chevy streetrod [Re: 41MoChev] #2309870
05/23/17 04:10 PM
05/23/17 04:10 PM
dogdays Offline
dogdays  Offline
If you have any sense at all you will build a 360. That 340 NOS block is a SCORE! Let the bidding begin.
R.
Re: New member - Building Mopar powered '41 Chevy streetrod [Re: 41MoChev] #2310382
05/24/17 02:50 PM
05/24/17 02:50 PM
VA
41MoChev Offline OP
41MoChev  Offline OP
VA
I wasn't planning on selling the 340 block, I know it is extremely rare.... Not saying there couldn't be an offer I can't refuse.
I mentioned that I have a 6-Pack intake manifold for it, but the manifold is not in great condition. It was over-ported for W2 heads and I have 340X heads. There are epoxies that can be used and should hold up, but I would rather have a new, or used manifold that hasn't been ported already. The problem is that Mopar or Edelbrock no longer make a 6-pack for the LA engine. If anyone knows of a source for one please let me know.
I was also hoping to outfit it with fuel injection units in place of the 3 carbs. There are sources to do that, but it would be much more expensive than the already costly 3 Holly 2bbl set-up.
I always welcome opinions and advice, but don't get your feelings hurt if I don't always follow them. I am pretty hard-headed. If I had followed the advice of most of my street rodder buddies, I wouldn't be putting a Mopar engine in a Chevy!
Re: New member - Building Mopar powered '41 Chevy streetrod [Re: 41MoChev] #2310648
05/24/17 10:57 PM
05/24/17 10:57 PM
VA
41MoChev Offline OP
41MoChev  Offline OP
VA
Question: I understand that the serpentine belt system from a magnum engine can be fitted to an LA engine. Is this true? If so, are there any issues such as water pump rotation direction?
Re: New member - Building Mopar powered '41 Chevy streetrod [Re: 41MoChev] #2310677
05/25/17 12:04 AM
05/25/17 12:04 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not easily.
The Magnum uses a shorter cam snout, no fuel pump eccentric provisions, with a correspondingly thinner timing chain cover.
You'd have to swap cam and cover or play spacing games to line everything up.
Re: New member - Building Mopar powered '41 Chevy streetrod [Re: 41MoChev] #2311263
05/25/17 11:43 PM
05/25/17 11:43 PM
VA
41MoChev Offline OP
41MoChev  Offline OP
VA
Well okay then. I'll keep that in mind. Thanks for the heads-up.
Re: New member - Building Mopar powered '41 Chevy streetrod [Re: 41MoChev] #2311811
05/27/17 12:03 AM
05/27/17 12:03 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
One thing for sure is I would not bore a virgin 340 block! Good 340 blocks are getting harder to come by, there is no reason to shorten its life span by a needless overbore, there are plenty of 340 seasoned blocks out there if you want to overbore one. In a street motor, unless your street racing, your not going to miss those few CI the overbore would provide. Throw the stroke kit at it, and add a power booster if that is not enough for you. I would also do the EFI. I would think as time moves forward the EFI is going to be easier to tune and dial in properly. Gene
Re: New member - Building Mopar powered '41 Chevy streetrod [Re: 41MoChev] #2313273
05/29/17 10:26 PM
05/29/17 10:26 PM
VA
41MoChev Offline OP
41MoChev  Offline OP
VA
Yeah, I won't be boring the 340... and in that case I may as well use the 360 block for this build and save the 340 block for something more worthy.
