Cuda hood emblem #2306234
05/17/17 06:56 PM
05/17/17 06:56 PM
Wisconsin
71duster414 Offline OP
Wisconsin
Would a 71 cuda with a build date 9/70 have a "plymouth" emblem on the front drivers side corner of hood or would it not be installed till later?
hoffmanhhr@gmail.com
Re: Cuda hood emblem [Re: 71duster414] #2308282
05/21/17 01:02 AM
05/21/17 01:02 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I say it does have it
Re: Cuda hood emblem [Re: 71duster414] #2308616
05/21/17 06:01 PM
05/21/17 06:01 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
PN 2998042 PLYMOUTH hood emblem for 1971.The 70 Cudas had the PLYMOUTH emblem PN 2998282 in the grill.
Re: Cuda hood emblem [Re: 71duster414] #2308693
05/21/17 08:37 PM
05/21/17 08:37 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
I believe he is asking since a lot of parts were not used up for the 1970 build and were being used up at the start of the 1971 build, did all rally hoods put on at the start of the 1971 production have the emblem or were even 1970 hoods with or without the emblem. Lots of parts on early 1971 had 1970 parts. Right inner fenders, rear wings, Shaker hoods, 70 rads, the list is much bigger. I have a 1971 Cuda with a Rally Hood SPD of Nov.5th and is has the emblem and is a crush zone 1971 hood. Never looked into the hoods to see if they had the emblem before this date of Nov.
Re: Cuda hood emblem [Re: hemicar1971] #2309693
05/23/17 11:43 AM
05/23/17 11:43 AM
Wisconsin
Wisconsin
My original hood doesn't have provisions underneath for the 3 holes. Did they use the stick on emblem instead of 3 pin in this case?? Or no emblem at all?
Re: Cuda hood emblem [Re: 71duster414] #2309930
05/23/17 06:22 PM
05/23/17 06:22 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the early '71 'cudas had holes drilled & speed-nuts without the recesses pre-stamped in the under hood structure
