Page 5 of 9 1 2 3 4 5 6 7 8 9
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2308094
05/20/17 07:03 PM
05/20/17 07:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By pittsburghracer
Originally Posted By KOS
Oh i forgot to mention Dave S local guy i bought 512 RB off a few years back that he replaced with a boneyard build 5.7 stock 6.1cam and heads with single turbo 3.23gears that ran 8.9s.he is also a member here if you want specifics on his build.
If that was pointed to me I'm not interested in a 8.9's power added build. My 512 will cover that with no adder, but thanks for the offer. Now it only comes down to was that number at one of the mineshaft east coast tracks or inland.
I know you want to play hard core that you wont
change.. but that 8.9 is with a STOCK engine that
a guy put a turbo on.. your car is light.. what
was his.. you better learn to open your mind a bit
or not
wave
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2308110
05/20/17 07:45 PM
05/20/17 07:45 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
His car must weigh 2000 lbs to run 8.90's with a 512 rb
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: The Shadow] #2308133
05/20/17 08:20 PM
05/20/17 08:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If I remember right he is running 2400 or
just a bit more.. still a good running car
wave
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2308169
05/20/17 09:30 PM
05/20/17 09:30 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
8.90 ET at 2400 lbs = 672 hp. 672hp from 512 cubes.....Not impressed.
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: STEFF] #2308177
05/20/17 09:44 PM
05/20/17 09:44 PM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
Who in the heck said the car weights 2400 pounds. Lol
I wish it did because then we would go even faster. Like I said you will never see me driving a two ton tessy. My street day's are over and I'm to young to need creature comforts. But this is a story for another day
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2308179
05/20/17 09:48 PM
05/20/17 09:48 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
Having built and raced every engine Mopar has ever built hands down a GEN 3 is the best bang for the buck. Using the example of 700HP show me a stock BB/SB or really for that matter a stock Gen2 head that will support 700HP. You might get there with a Gen 2 head with work. A 700HP big block even of you start with a block you already have will cost you more. If your starting from scratch you need
Headers good headers are the same price for either
After market oil pan I have yet to see a stocker that will support 700hp
Heads --You can use stock 6.1 or apache heads
Rockers---You can use stock gen 3 rockers on a 700hp build
Rotator is the same money
Machine work is the same
No brainer I built one and the only reason I would build a BB or Gen 2 hemi now is if I would want to go NSS racing again (which I do) but I hate the thought of building another BB!!!!
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: MR_P_BODY] #2308191
05/20/17 10:12 PM
05/20/17 10:12 PM
K
KOS Offline
KOS  Offline
K
or not
wave
betcha theres more $$ in that 512 than the turbo 5.7 and its around 3100lbs.im convinced gen IIIs are not the way to go LOL
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: biff426] #2308209
05/20/17 10:37 PM
05/20/17 10:37 PM
PA.
"Little"John
"Little"John
PA.
I lurk over on the Moparts gen 3 area because believe it or not I am open minded and enjoy reading and studying before I leap. As for costs I have 2800.00 in my mega block ready to assemble, 2200.00 in my rotating assembly, and under 1200.00 in my 440-1 heads with Harlan Sharp rockers with upgraded 2.250 valves (I will probably go with a set of T&D rockers if valve to piston permit). Indy intake was in a package deal and 500.00 in the alcohol toilet if I go that way. It adds up but still what I consider budget build as I shy away from some of the "ragazine" tricks that drive up costs. But like I said my eyes and ears are open while you guys get a hints figured out. I can only hope that is a misprint on what a gen 3 guy said lifters cost in that one post over there.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2308440
05/21/17 12:53 PM
05/21/17 12:53 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
Not sure where you find $1200 -1 heads with Harland sharp rockers or a $2800 mega block ready to roll hell just find a mega block worth building right now. This is why I will put a gen 3 stroker together and run 10.0 index vs NSS
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: STEFF] #2308443
05/21/17 12:58 PM
05/21/17 12:58 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
8.90 in anything with doors n/a... I'm impressed.
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2308494
05/21/17 01:56 PM
05/21/17 01:56 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Wonder if ptsbracer get lexan, fiberglass and holesaws as cheap as engine parts
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2308502
05/21/17 02:00 PM
05/21/17 02:00 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
IIRC he removed the glass doors from the car in favor of more "friendly" stock doors with roll up glass.
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: J_BODY] #2308518
05/21/17 02:24 PM
05/21/17 02:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No kidding, and it takes a lot of work weather old school or new just seems a bit easier w/late model and EFI. I know I came off very strong and negative about the new stuff so my bad there, it's just a personal preference thing and there's no right or wrong until stubborn guys like myself and a few others make it personal. I love the positive and negative results I get from carbs and although messy and a pain at times, I just cant see myself on a laptop tuning. Hell, I cant even post pics here............... laugh2 N/A Old school has been my goal forever so that's where I`ll stay and shoot for that elusive 5.99.............. beer
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2308894
05/22/17 01:55 AM
05/22/17 01:55 AM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
If one did a graph showing age to what type engine, I think it would show real clear who likes what. Heck for the sake of argument, if either engine was free with all the goodies, which one then.
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: J_BODY] #2308925
05/22/17 05:51 AM
05/22/17 05:51 AM
PA.
"Little"John
"Little"John
PA.
ack in his
Ya I could start a weight gain post. Between kicking my son out of the car and back in his, stock steel doors with stock wind up window, alternator, exhaust, R3 block, diaper, racepak and electrical upgrades, and a few other goodies I added 250-300 pounds to the car. Lol. I call it my old man car. Race it, drive it in the trailer and climb out the window, and go home. Matt went to take the hood off at the track last week and I asked him what the heck he was doing.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2308943
05/22/17 09:42 AM
05/22/17 09:42 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Lol. Thats how I am and exactly why I went g3. Hyd roller ftw
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2309011
05/22/17 12:51 PM
05/22/17 12:51 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
I'm exploring building a carb'd Gen 3 for my dirt late model deal... rebuilding a small block 383 right now.
Seems to me it will be cheaper than buying a Ritter block and W-2 or ported aftermarket heads. Plus the good Eagle heads are better than most any small block head and are on the shelf at my local dealer 6 blocks away.
The juice lifter deal is my only question mark... can they live for 25 laps on a 1/2 mile at 7,000 rpm's? The T&D/Jesel numbers don't fit my budget right now so solid lifters are pretty much a no go.
We'll see.....
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2309078
05/22/17 02:15 PM
05/22/17 02:15 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Remembering back to when the 2.2 was the only "factory performance" engine platform, I see alot of humor in these discussions....We're actually pretty lucky to have anything, considering how small our overall volume is.
Rich H.
Esse Quam Videri
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: ZIPPY] #2309121
05/22/17 03:04 PM
05/22/17 03:04 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Amen brother!
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: DaytonaTurbo] #2309259
05/22/17 07:08 PM
05/22/17 07:08 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By DaytonaTurbo
I'll stick with the old school junk. Regardless of what anyone says, the Gen 3's are more expensive to build and install. The headers, oil pans and engine mounts they require are not cheap. The rotating assemblies in side the junkyard pickup truck 5.7's are just that, junk. For a fun, 500-600hp street car, an old school RB build can be done for a fraction of the cost without roller-this or stroker-that.
Thats me as I am old school top to bottom. But thats just me as I love what I grew up with. Even on brand X as if I see a nice 69 Chevelle SS 396 and see a newer LS under the hood its not what I like to see under there as I want to see a 396 or BB Chevy under its hood. And as I say thats just me. Nothing wrong with anyone going with a modern eng in their old muscle if thats what they like. I like the NSS racing alot and like to see what eng belongs under their hoods as thats what floats my boat. But the new eng will run good and I dont knock anyone for building what they like as you have to build what you like.
I honestly think many of us including me were really surprised to see the muscle cars return with all the power they have with the power adders as I think most like me felt we would never see anything like this from the factory again after the muscle cars died in the 70's. Bottom line is new or old Mopar they are all Mopars so we should like them all as I do. I just prefer old school for myself. But there is alot of modern parts now for the old school engines that help them run alot better also. Ron
