What size T-bars for SS springs on ebod? #2307701
05/20/17 12:32 AM
05/20/17 12:32 AM
Sonora, Ca
Bomber Offline OP
Bomber  Offline OP
Sonora, Ca
I thought I had them already, but I can't find them anywhere. It's been 15 years since I did the suspension and who knows what happened to them, and the info I had. Anyway, I'm back on this car after being out of the hobby, and I'd like to finish the suspension. I still need tbars to match the SS springs(same both sides), shocks, and swaybar(s) to finish it. I suck at searching, so figured I'd just ask. Thanks in advance.
Re: What size T-bars for SS springs on ebod? [Re: Bomber] #2307710
05/20/17 12:57 AM
05/20/17 12:57 AM
Sonora, Ca
Bomber Offline OP
Bomber  Offline OP
Sonora, Ca
HA! Found my file, and what I need (.960). And I don't have SS springs after all smile
Re: What size T-bars for SS springs on ebod? [Re: Bomber] #2308052
05/20/17 05:43 PM
05/20/17 05:43 PM
IN
ahy Offline
ahy  Offline
IN
What are you doing with the car? Reason for asking it affects T bar size (that would suit).
.96" is a bit of an upgrade over stock but most folks are running bigger now. 1.00" is nice size for moderate performance and not harsh at all.
Re: What size T-bars for SS springs on ebod? [Re: ahy] #2308168
05/20/17 09:30 PM
05/20/17 09:30 PM
Sonora, Ca
Bomber Offline OP
Bomber  Offline OP
Sonora, Ca
It's for fun. Lots of corners where I live, but the roads aren't the best, so I don't want to get too aggressive. I'm a little lighter up front too (alum headed sb, bat in trunk, no PS)and I think the .960 match the springs the best. That said, if you have a proven set up, I'd be foolish not to listen smile
Re: What size T-bars for SS springs on ebod? [Re: Bomber] #2308293
05/21/17 01:25 AM
05/21/17 01:25 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Before Mitch says it, get big ones. .960 on an e body is tiny.
Mopar to the bone!!!
Re: What size T-bars for SS springs on ebod? [Re: 72Swinger] #2309876
05/23/17 04:24 PM
05/23/17 04:24 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
GET BIG ONES!!!! I have progressively tried different sizes, but keeping in mind the roads you'll be driving. My 1.24" are biggest that will fit in through the 1.25" hex opening... Firm Feel can make them for you (they just made a set of 1.24 for a friend of mine). For regular cruising, 1.0 to 1.12 are OK and better than stock... but you'll only wonder why you didn't go a little stiffer. Don't be afraid... BUT, also get better shocks to match (you pay for what you get).... the double adjustables from QA1, Viking, etc will allow you to finite-tune the ride.
I've actually ran/raced (AX) the SS springs.. after having them de-arched... and they are OK with TBs say.. up to ~1.18 as a good match... but again, better shocks have to be mated.
you can always adjust the ride a little further pending the tire pressures, and the the choice of tire sizes makes a factor... 60-series, 50-series, 40-series, etc.. shorter sidewall = stiffer ride combined with whatever tire PSI you run...
Good luck in whatever you decide.... bigger TBs are one of the best improvements you'll make.
