shocks for my super stock springs?? #230799
02/20/09 08:53 PM
02/20/09 08:53 PM
Nebraska
Lime446 Offline OP
Lime446  Offline OP
Nebraska
I'm getting ready to order shocks for the duster. I'll be running super stock springs. What's everyone runnin? Dustin
Re: shocks for my super stock springs?? [Re: Lime446] #230800
02/20/09 09:05 PM
02/20/09 09:05 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Rancho 9000s
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: shocks for my super stock springs?? [Re: Lime446] #230801
02/20/09 09:06 PM
02/20/09 09:06 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
Rancho 9000 set on 7 rear and calverts'90/10s on the front.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: shocks for my super stock springs?? [Re: Lime446] #230802
02/20/09 11:01 PM
02/20/09 11:01 PM
Rowlett, TX
74DusterP457 Offline
mopar addict
mopar addict
Rowlett, TX
Ditto on the Ranchos
As an alternative, you can use standard length shocks with extensions.
Re: shocks for my super stock springs?? [Re: Lime446] #230803
02/20/09 11:09 PM
02/20/09 11:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I wouldnt buy Rancho's, if you ask these guys running
them you will see that they are right at the max setting,
that tells me they are out of adjustment and more than
likely could use a stronger valving. If your going
to buy shocks get good ones
Re: shocks for my super stock springs?? [Re: MR_P_BODY] #230804
02/20/09 11:21 PM
02/20/09 11:21 PM
Salina ks
572_dup2 Offline
Back On The Bumper!!
572_dup2  Offline
Salina ks
I tired ranchos on 2 different cars. I got better 60's out of both cars with shocks of ramcharger trucks. Just what worked 4 me.
Shawn Jennings
Re: shocks for my super stock springs?? [Re: MR_P_BODY] #230805
02/20/09 11:26 PM
02/20/09 11:26 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I got mine for $12 off ebay from a dodge dealership that had new take offs from a brand new 2007 3/4 ton diesel truck. All I had to do was drill the shock bushings out one drill size bigger on a drill press (run the bit slow, held the shock by hand, drill halfway thru each side, PERFECT fit on the mounts). Stiff buggers they are, but took care of my porpoising problem.
Re: shocks for my super stock springs?? [Re: Hot 340] #230806
02/20/09 11:33 PM
02/20/09 11:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The problem with running a stock(non adjustable) is
just that... you dont have any adjustment. All tracks
are not created equal
Re: shocks for my super stock springs?? [Re: MR_P_BODY] #230807
02/21/09 12:18 AM
02/21/09 12:18 AM
Nebraska
Lime446 Offline OP
Lime446  Offline OP
Nebraska
I definitely want adjustability. Every track is different and so is every day. I've got enuff spare parts in the trailer already I don't really want to add shocks to the list . Thanks for the imput thus far. Dustin
Re: shocks for my super stock springs?? [Re: MR_P_BODY] #230808
02/21/09 09:26 AM
02/21/09 09:26 AM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
Has anyone here ever played around with extra clamps on these springs?
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: shocks for my super stock springs?? [Re: Steve1118] #230809
02/21/09 09:40 AM
02/21/09 09:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Clamp all of the front segments. Years ago I even
clamped some bar stock to the front of the springs,
you cant make the front stiff enough
Re: shocks for my super stock springs?? [Re: MR_P_BODY] #230810
02/21/09 10:30 AM
02/21/09 10:30 AM
Steve1118 Offline
Steve1118  Offline
Thanks. I've been running them for years, but have never really messed around with "tuning" them. My car leaves hard, but seems to have a awful lot of rise. It also picks the left side up more than the right, and I'd like to even that out. I am sort of scared of busting something up, and would also like to see if it can pick up a bit on the short times.
I've also been using the SS shocks, but am going to try a more stiffer(?) shock, I found a couple of new Rough Country truck shocks here we got in a parts deal years back that extend plenty but seem to be stiffer in valving. Ths shocks I am using are bending at the bottom, assuming from the excessive lifting. I am also going to shorten the rear shackle a bit (I have those adjustable jobs with the spring in the middle hole).
I know ladder bars are the way to go, but, to be frank, I am not that motivated right now.
Re: shocks for my super stock springs?? [Re: Steve1118] #230811
02/21/09 10:41 AM
02/21/09 10:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You have a couple of things going on
1st is the body lift, thats controlled by the shocks,
I'm a firm believer in quality adjustable shocks,
on your application a single adjustable will work
(singles adjust the extension which is adjusted for
the body lift/raise for launch, the dual adjustable
has a compression adjustment for down track)
2nd is body twist, you could put a anti roll bar on
to take that out(also a rear sway bar is the same
thing BUT is mounted in rubber and the rubber gives
up some of the roll where anti roll bars are all
solid mounted in bearings or something else with
heim joints at the ends
Re: shocks for my super stock springs?? [Re: MR_P_BODY] #230812
02/21/09 10:51 AM
02/21/09 10:51 AM
Steve1118 Offline
Steve1118  Offline
Last year on hard launches the car would pull to the right slightly, nothing major but noticeable. I am assuming that is because of the uneven lift and perhaps pivoting on the snubber.
I'll try your tips....stiffen the front segment a bunch, adjustable shocks. And when the snow melts, someday, (it seems like this winter has been twenty years long), I'll try it.
Re: shocks for my super stock springs?? [Re: Lime446] #230813
02/21/09 11:35 AM
02/21/09 11:35 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
I have bin running SS/Springs and changed my combo a fue times over the years. I tryed the Ranhcos and The mopars long shocks but thay did not have enough bomp and would let the rear bounce up in the car after the hit . What has worked good for me are shocks from a 94 4x4 Dakota, I have a half leaf on top of the front section of the springs that goes from the front spring eye to the back of the spring perch, thay are clamped at every leaf in the front section. I allso use lowering blocks to get the ride highth. I like the rear no more than 2" higher than the front mesured at the sill.
Good luck and have fun
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: shocks for my super stock springs?? [Re: wildcargo] #230814
02/21/09 07:40 PM
02/21/09 07:40 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I am using the Pro-Comp Dodge truck off-road shocks for my car.I have been looking at the Afco single adjustable units that Mancini sells.I just don't race my car often enough to justify big dollar rear shocks
Gus
64 Plymouth Savoy
Dana 60
Re: shocks for my super stock springs?? [Re: fourgearsavoy] #230815
02/21/09 10:35 PM
02/21/09 10:35 PM
ohio
1Bad440 Offline
1Bad440  Offline
ohio
I tried Comp 3/ways now I run 2000 Dodge Ram 3/4 ton factory replacement shocks from napa with the 002 & 003 S/S springs
