B1 headers? #230606
02/20/09 05:00 PM
02/20/09 05:00 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Hello, does anyone make a bolt on header for a original B1 head on a low deck block. Or do they all have to be custom made? Thanks
Re: B1 headers? [Re: 70VcodeCoronetRT] #230607
02/20/09 05:04 PM
02/20/09 05:04 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Mad Dog does
www.maddogheaders.net
Mild Steel. Very Nice. Good Price
Re: B1 headers? [Re: joshking440] #230608
02/21/09 01:57 AM
02/21/09 01:57 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
No, not really....They will all physically bolt up to the heads, the exhaust pattern is the same. The heads are raised a good deal, they are also a good deal wider than a stock type or Indy head. Lastly the exhaust port on a B1 once ported are very large, most shelf headers will not be big enough to cover the opening. But I have seen TTI's and Fenderwell headers run with B1's. I am gonna assume those heads dont have a ton of port work though.
If it helps not sure it will here are my headers. The openings in the flange BARELY cover the port. Note the area around the flange between the port opening and the edge of the flange. BTW those notches in the flange are for head stud clearance.
chrome molding for [Re: 70VcodeCoronetRT] #230609
02/21/09 02:36 AM
02/21/09 02:36 AM
)Minnesota
carnivore Offline
carnivore  Offline
)Minnesota
Hi guy's, I'm looking for the chrome molding that goes on the trunk of a 68 barracuda notch. Can anybody help.?
Re: B1 headers? [Re: Al_Alguire] #230610
02/21/09 03:21 AM
02/21/09 03:21 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
[/quote
Not totally true Al. Maddog has a jig for the original B-1 for an a body and b-body underchassis as well as a very good size flange opening.
Re: B1 headers? [Re: joshking440] #230611
02/21/09 10:04 AM
02/21/09 10:04 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
If you look at the bolt hole CL in relationship to the port opening CL they are not centered like a stock head. The port is raised 1/8 or better. This is where the trouble with off the shelf headers comes in. They will bolt up but the roof of the port and the top of the tube opening do not line up.
Bob
Re: B1 headers? [Re: fbs63] #230612
02/21/09 02:24 PM
02/21/09 02:24 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
The exhaust port on B1s are BIG. much larger than even Indys. Thats why you have to have a custom made flange...Big Dad on this board has them..a nd you can get them from Headers by Ed, too.
