Trans Fluid #230513
02/20/09 03:16 PM
02/20/09 03:16 PM
NW Minnesota
Maximus_Wedges Offline OP
NW Minnesota
I know the trans. fluid topic is a dead horse that gets beaten once in a while. My question is to the guys that have info on running heavy duty tractor trans fluid in a race 727. We broke a drive shaft on the last race of the 08 season and need to tear down for inspection. QUICK D100 has most graciously offered to help. (Thanks Dave) I stock bulk heavy duty tractor trans fluid on my farm. With every thing drained this may be good time to ditch the type F.
480 ci B stroker, coan 5500 converter 3000 lb car. what say you? Thanks in advance guys
Re: Trans Fluid [Re: Maximus_Wedges] #230514
02/20/09 03:35 PM
02/20/09 03:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have no idea what the bulk trans fluid is but I
use the type F in my trans, been for years. Why do
you want to ditch the type F, just because you have
all of the bulk.... what is the bulk
Re: Trans Fluid [Re: MR_P_BODY] #230515
02/20/09 03:44 PM
02/20/09 03:44 PM
NW Minnesota
NW Minnesota
I could get the spec. number but it lists the John Deere, Case IH and other tractor powershift trans. applications it is made for. I'd just like to keep the oil inventory less cluttered. A while back a few guys said they were using it and it got me thinking.
Re: Trans Fluid [Re: Maximus_Wedges] #230516
02/20/09 03:53 PM
02/20/09 03:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In my IH it uses 10 weight hyd oil for the trans which
is a common sump for my hyd cyinders
Re: Trans Fluid [Re: MR_P_BODY] #230517
02/20/09 04:06 PM
02/20/09 04:06 PM
NW Minnesota
NW Minnesota
It is a 10 wt. hyd fluid. It is a tougher spec. than std. cyl. lift oil. that's about all I
know about it. Mabey the fellows that were using it in their drag cars will show up or some of the oil gurew's will chime in.
Re: Trans Fluid [Re: Maximus_Wedges] #230518
02/20/09 04:15 PM
02/20/09 04:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A lot of people have reported good experiences with the JD fluid in the Torqueflite. Mostly street/mild competition, I don't remember any reports from dedicated racers.
Re: Trans Fluid [Re: John_Kunkel] #230519
02/20/09 04:45 PM
02/20/09 04:45 PM
Q
Quicktree Offline
Quicktree  Offline
Q
go synthetic, amsoil is the best. I used valvoline syntec.
Re: Trans Fluid [Re: Quicktree] #230520
02/20/09 05:12 PM
02/20/09 05:12 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
do you mean dex/merc 4?
Re: Trans Fluid [Re: blownzoom440] #230521
02/20/09 05:23 PM
02/20/09 05:23 PM
Q
Quicktree Offline
Quicktree  Offline
Q
no full syntec
Re: Trans Fluid [Re: Quicktree] #230522
02/20/09 06:13 PM
02/20/09 06:13 PM
Newark,De
hemi471 Offline
hemi471  Offline
Newark,De
This what I use.
Re: Trans Fluid [Re: hemi471] #230523
02/20/09 09:01 PM
02/20/09 09:01 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
This what I use.
I have a case ordered right now
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Trans Fluid [Re: dusturbd340W5] #230524
02/20/09 10:09 PM
02/20/09 10:09 PM
id usa
4spdfury Offline
4spdfury  Offline
id usa
so the mercon 3 is not a good fluid for are trannies. i have a stock trans and have been wondering if this was the right fluid.
Re: Trans Fluid [Re: 4spdfury] #230525
02/20/09 10:16 PM
02/20/09 10:16 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I don't think that has been said here.
It has only been said that there is better stuff, and there is.
Dextron3/mercon3 FAR exceeds any of the original specs a torqueflite would have had, and is PERFECTLY acceptable in a drag or street car.
Given the choices of fluids at a modern parts store, the correct fluid for a torqueflite is Dextron3/mercon3.
Re: Trans Fluid [Re: dave571] #230526
02/20/09 10:36 PM
02/20/09 10:36 PM
Wellington, Ohio (20 minutes f...
MrMoparRacing Offline
This is what I use.
Re: Trans Fluid [Re: MrMoparRacing] #230527
02/20/09 10:44 PM
02/20/09 10:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the cheap type F you get at the local parts
store. I tried the big buck stuff... it didnt do a
thing for wear or ET
Re: Trans Fluid [Re: MR_P_BODY] #230528
02/21/09 06:02 AM
02/21/09 06:02 AM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
What about Mopar ATF plus 4 ? It`s full synthetic and part code is 05013457AA
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: Trans Fluid [Re: MR_P_BODY] #230529
02/21/09 06:20 AM
02/21/09 06:20 AM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
Re: Trans Fluid [Re: Maximus_Wedges] #230530
02/21/09 06:30 AM
02/21/09 06:30 AM
nielsville, minn.
Q
quickd100 Online content
quickd100  Online Content
Q
nielsville, minn.
Well Kevin if you want to be the 'test mule' I'll help you out. If things go south with the hydralic fluid I'll rebuild it. Dave
Re: Trans Fluid [Re: MR_P_BODY] #230531
02/21/09 07:33 AM
02/21/09 07:33 AM
Q
Quicktree Offline
Quicktree  Offline
Q
it reduces wear and temp, you old geezers will never learn
Re: Trans Fluid [Re: Quicktree] #230532
02/21/09 08:38 AM
02/21/09 08:38 AM
Newark,De
hemi471 Offline
hemi471  Offline
Newark,De
Sort of like spending 20K on a motor, then using cheap pepboys oil in. You can do it, just not me.
