Re: Help! Vin seems fishy
[Re: 68GTS383]
#2305004
05/15/17 05:48 PM
05/15/17 05:48 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
Looking at a 65 (supposedly) Barracuda. Looking at the stainless Vin plate in the door jamb.Rivets missing,plate glued on.Looks like someone tried stamping V8 in front of the numbers which are 52641785. Where did this plate come from? Thanks V8 = V8 Barracuda 5 = 1965 2 = Hamtramck, MI assembly plant 641785 = VIN serial number Hamtramck a-bodies started at 500001 ** 641785 would be 141,785th a-body assigned VIN March '65 build
[Re: 68GTS383]
#2305058
05/15/17 07:26 PM
05/15/17 07:26 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
What is it exactly correct for? A 65 Plymouth Barracuda, that is what you were asking about isn't it?
[Re: 68GTS383]
#2305095
05/15/17 08:07 PM
05/15/17 08:07 PM
RapidRobert
Agreed, they stamped the first 2 digits suspiciously different. Way back On another site the DMV would not accept the sale when they inspected it cuz they thought that that was a fraud & the guy went online & downloaded some pics /info & showed it to them that confirmed to them that that was normal. Tho "V8" would make a person skeptical. might be just a coincidence. Is it a V8? Or was it if not original (has a dropped crossmember).
[Re: 68GTS383]
#2305100
05/15/17 08:17 PM
05/15/17 08:17 PM
RapidRobert
I think you're in good shape (ID wise). EDIT I think that it is "V8" is just a coincidence.
