Help! Vin seems fishy #2304904
05/15/17 02:50 PM
05/15/17 02:50 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
Looking at a 65 (supposedly) Barracuda.
Looking at the stainless Vin plate in the door jamb.Rivets missing,plate glued on.Looks like someone tried stamping V8 in front of the numbers which are 52641785. Where did this plate
come from? Thanks
Re: Help! Vin seems fishy [Re: 68GTS383] #2304912
05/15/17 03:07 PM
05/15/17 03:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That is exactly correct.
Don't be the exception.
Re: Help! Vin seems fishy [Re: 68GTS383] #2304922
05/15/17 03:26 PM
05/15/17 03:26 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It should be spot welded on in 65
Re: Help! Vin seems fishy [Re: Supercuda] #2304924
05/15/17 03:29 PM
05/15/17 03:29 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
What is it exactly correct for?
Re: Help! Vin seems fishy [Re: 68GTS383] #2304978
05/15/17 05:10 PM
05/15/17 05:10 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The first 2 digits are stamped differently than the rest, the plate is spot welded on with the 2 holes left empty.
Re: Help! Vin seems fishy [Re: 68GTS383] #2305004
05/15/17 05:48 PM
05/15/17 05:48 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
come from? Thanks
V8 = V8 Barracuda
5 = 1965
2 = Hamtramck, MI assembly plant
641785 = VIN serial number
Hamtramck a-bodies started at 500001 ** 641785 would be 141,785th a-body assigned VIN March '65 build
Re: Help! Vin seems fishy [Re: 68GTS383] #2305058
05/15/17 07:26 PM
05/15/17 07:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
A 65 Plymouth Barracuda, that is what you were asking about isn't it?
Re: Help! Vin seems fishy [Re: Supercuda] #2305085
05/15/17 07:54 PM
05/15/17 07:54 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
Yes, a 1965 Barracuda that I am thinking about buying for my son
Re: Help! Vin seems fishy [Re: 68GTS383] #2305095
05/15/17 08:07 PM
05/15/17 08:07 PM
Agreed, they stamped the first 2 digits suspiciously different. Way back On another site the DMV would not accept the sale when they inspected it cuz they thought that that was a fraud & the guy went online & downloaded some pics /info & showed it to them that confirmed to them that that was normal. Tho "V8" would make a person skeptical. might be just a coincidence. Is it a V8? Or was it if not original (has a dropped crossmember).
Re: Help! Vin seems fishy [Re: RapidRobert] #2305097
05/15/17 08:12 PM
05/15/17 08:12 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
273 2bbl bucket seats with auto in floor. White ext gold int
Re: Help! Vin seems fishy [Re: 68GTS383] #2305100
05/15/17 08:17 PM
05/15/17 08:17 PM
I think you're in good shape (ID wise). EDIT I think that it is "V8" is just a coincidence.
Re: Help! Vin seems fishy [Re: RapidRobert] #2305121
05/15/17 08:51 PM
05/15/17 08:51 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
No issues, VIN is correct. twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: Help! Vin seems fishy [Re: Rhinodart] #2305207
05/15/17 10:46 PM
05/15/17 10:46 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
yes "V8" is a bit of coincidence
V = Valiant or Barracuda (Plymouth A-body) with a V8
8 = Barracuda (if A-body) or TAXI (if B or C-body)
FYI: first digit is "1" for a /6 Valiant or Barracuda
