E-body BB/SB auto linkage the same or different???? #230450
02/20/09 01:24 PM
02/20/09 01:24 PM
Fairfield, Ohio
holtzdog55 Offline OP
Fairfield, Ohio
Going from a 340 to 440....is the shifter hardware I have going to work?? if so great!! If not, what needs to change/what pieces need replaced??
Finally Done....BEERS!!!
Re: E-body BB/SB auto linkage the same or different???? [Re: holtzdog55] #230451
02/20/09 02:07 PM
02/20/09 02:07 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
Since I am assuming both are 727s, the shifter linkage should work fine assuming all of the correct bosses are present on the new trans. I have seen some transmissions that have more or less bosses cast into them depending on original application. Just make sure your new trans has all the same ears as were used on the old one.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: E-body BB/SB auto linkage the same or different???? [Re: phantomx] #230452
02/20/09 02:14 PM
02/20/09 02:14 PM
Fairfield, Ohio
Fairfield, Ohio
what are bosses??
Re: E-body BB/SB auto linkage the same or different???? [Re: holtzdog55] #230453
02/20/09 02:28 PM
02/20/09 02:28 PM
NE Ohio
71 FJ6 Charger Offline
NE Ohio
Bosses = mounting points
'71 383HP FJ6 Charger SE
Re: E-body BB/SB auto linkage the same or different???? [Re: 71 FJ6 Charger] #230454
02/20/09 02:36 PM
02/20/09 02:36 PM
Fairfield, Ohio
Fairfield, Ohio
Thanks for all the help...I'll get it checked out
Re: E-body BB/SB auto linkage the same or different???? [Re: holtzdog55] #230455
02/20/09 03:14 PM
02/20/09 03:14 PM
Pa
GaryB Offline
super street
GaryB  Offline
super street
Pa
I changed my ebody from 318/904 to 440/727 and no problems with linkage. I even used the same kickdown linkage for the carb to trans. Hope that helps.
Re: E-body BB/SB auto linkage the same or different???? [Re: GaryB] #230456
02/20/09 03:37 PM
02/20/09 03:37 PM
Fairfield, Ohio
Fairfield, Ohio
Thanks again...
Any and ALL info is helpful sometime down the road
Re: E-body BB/SB auto linkage the same or different???? [Re: holtzdog55] #230457
02/20/09 04:05 PM
02/20/09 04:05 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I pulled a floor shifter/console out of a 904 equiped car and put it into a 727 equiped car, everything worked perfect.
Re: E-body BB/SB auto linkage the same or different???? [Re: phantomx] #230458
02/20/09 05:35 PM
02/20/09 05:35 PM
Fairfield, Ohio
Fairfield, Ohio
Travis..
Yes....both 727's
Re: E-body BB/SB auto linkage the same or different???? [Re: holtzdog55] #230459
02/21/09 08:03 AM
02/21/09 08:03 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
I used a kickdown rod from a 340 motor 727 application on a 383 motor 727 and it worked fine.
