E-body BB/SB auto linkage the same or different????
#230450
02/20/09 01:24 PM
02/20/09 01:24 PM
Posts: 445 Fairfield, Ohio
holtzdog55
Fairfield, Ohio
Going from a 340 to 440....is the shifter hardware I have going to work?? if so great!! If not, what needs to change/what pieces need replaced?? Thanks
Finally Done....BEERS!!!
Re: E-body BB/SB auto linkage the same or different????
[Re: holtzdog55]
#230451
02/20/09 02:07 PM
02/20/09 02:07 PM
Posts: 982 W. Sacto CA. USA
phantomx
W. Sacto CA. USA
Since I am assuming both are 727s, the shifter linkage should work fine assuming all of the correct bosses are present on the new trans. I have seen some transmissions that have more or less bosses cast into them depending on original application. Just make sure your new trans has all the same ears as were used on the old one. Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
