Re: valve to piston clearance
[Re: RiskyRickey]
#2300245
05/06/17 06:56 PM
05/06/17 06:56 PM
RapidRobert
Yes, pull a pair of valve springs on cyl #1 with an on head valve spring compressor & sub in a pair of light checking springs. with some 3/8 white nylon rope in the cyl to keep from dropping a valve & then check the VP you have now for a start. there is a range of crank degrees (each different) where the 2 respective valves are the closest to the piston. Others will chime in.
[Re: RiskyRickey]
#2300260
05/06/17 07:17 PM
05/06/17 07:17 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Run the piston up to TDC on the exhaust stroke, remove the valve cover and use a pry bar on the rocker arm to push the valve down against the piston...use a dial indicator to check the valve's travel.
[Re: RiskyRickey]
#2300316
05/06/17 09:01 PM
05/06/17 09:01 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
You need to check with the checking springs as mentioned usually from 15 before TDC through 15 after TDC. If using a cam with the same lobes intake/exhaust, and the cam is installed straight up, the valve distance will be the same at TDC from the head seat. Clearance may be slightly different because the valve reliefs may be different depth, and because the valves open at an angle, the larger diameter intake valve should have less clearance. Advancing and retarding the camshaft installed position will change the P-V clearance, Advancing will close the exhaust sooner and open the intake sooner, so in an advanced install position, the intake should have less clearance (given the same cam lobes, but usually the exhaust is larger duration.)
[Re: RiskyRickey]
#2301004
05/08/17 02:48 AM
05/08/17 02:48 AM
RapidRobert
I would try the stacked feeler gauge method. I'd clamp em in the middle or somewhere other than the normal tips so when done you can still use em normally cuz the tips will still be pristine.
[Re: Sxrxrnr]
#2301118
05/08/17 12:44 PM
05/08/17 12:44 PM
RapidRobert
Assuming you are talking solid and not hydraulic lifters, the rules depending upon approach may be different. Yes, with juice lifters, with a pair of junk lifters I lock the cups solid with JB weld/washers the same distance below the snap ring as the preload I will be using then use them for checking purposes.
