Silly 318 question
#2299956
05/06/17 10:01 AM
05/06/17 10:01 AM
Posts: 1,308 Spencer NY
killermopar
Spencer NY
I know the 318 isn't regarded as a performance engine, but that's what I've got lying around right now. I also have a set of closed chamber w2 heads with 2.02 valves. The chambers are 57cc and the ports are stock. I have all the valvetrain, and the intake manifold. With thin head gaskets it should be about 9.7-1. My question is, what is a good cam for this in a 2800 lb Dart bracket car with 4.10 gears and a 3000 stall converter?
Re: Silly 318 question
[Re: killermopar]
#2300193
05/06/17 04:33 PM
05/06/17 04:33 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Cam is my motor is only 231@ 50. Gonna need some converter to make it run. I shift at 6200, trap at 6 to keep it street friendly. Know it would like more gear.
