Silly 318 question
#2299956
05/06/17 10:01 AM
05/06/17 10:01 AM
Posts: 1,308 Spencer NY
killermopar
Spencer NY
I know the 318 isn't regarded as a performance engine, but that's what I've got lying around right now. I also have a set of closed chamber w2 heads with 2.02 valves. The chambers are 57cc and the ports are stock. I have all the valvetrain, and the intake manifold. With thin head gaskets it should be about 9.7-1. My question is, what is a good cam for this in a 2800 lb Dart bracket car with 4.10 gears and a 3000 stall converter?
Re: Silly 318 question
[Re: killermopar]
#2300193
05/06/17 04:33 PM
05/06/17 04:33 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
Cam is my motor is only 231@ 50. Gonna need some converter to make it run. I shift at 6200, trap at 6 to keep it street friendly. Know it would like more gear.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
