Is this much qtr window misalignment "normal" #230011
02/19/09 09:23 PM
02/19/09 09:23 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
I managed to get the quarter windows in my '67 'cuda 'vert. and it appears that even with the qtr window stops all the way up the qtr window does not meet the door window at all...
I have not put the top on to see how it fits, with the door, but I would expect it to be closer then this; is this reasonable? The door window is adjusted so it hits the top of the wingdig seal, I could see it somewhat cocked, but not by an inch or more....
The door is aligned nicely with the body...
Re: Is this much qtr window misalignment "normal" [Re: 6T6Cuda] #230012
02/19/09 11:18 PM
02/19/09 11:18 PM
Back In Iowa
belv2vert66 Online content
belv2vert66  Online Content
Back In Iowa
Good luck......I did mine with my top up and I have never cussed so much in my life.......Do you have a service manual for your car ? If I remember right mine were even across the top of both pieces of glass
Re: Is this much qtr window misalignment "normal" [Re: belv2vert66] #230013
02/20/09 01:54 AM
02/20/09 01:54 AM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
My brother just put the glass back in his 67 Coronet conv and his window tops line up fine.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: Is this much qtr window misalignment "normal" [Re: 6T6Cuda] #230014
02/20/09 04:27 AM
02/20/09 04:27 AM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
Not sure your door regulator works like a B-Body but if so, check for a lock nut common to your regulator that will be exposed on your door. Lock nut is threaded to a post with a slot on it. Your regulator has a cam on it and this adjustment sets the amount your door window can go up. It appears that this is the case.
Re: Is this much qtr window misalignment "normal" [Re: 6T6Cuda] #230015
02/21/09 12:17 AM
02/21/09 12:17 AM
Great White North
Furyman Offline
Furyman  Offline
Great White North
Maybe you have the wrong door glass ?? There are three types...convert,fastback and notchback.Notchback glass is curved on top edge ...you don't have that installed but possibly you have a fastback piece.
"Long Live Mopars"
Re: Is this much qtr window misalignment "normal" [Re: 6T6Cuda] #230016
02/23/09 09:45 AM
02/23/09 09:45 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: Is this much qtr window misalignment "normal" [Re: Challenger 1] #230017
02/23/09 11:52 AM
02/23/09 11:52 AM
WI
RestoRick Offline
RestoRick  Offline
WI
You really should have the top frame in place...
My guess would be that the rear door glass stop is too high. Once that's lowered,
then the quarter glass will need to be shifted forward a bit and the rear stop adjusted lower, which will make it rotate to match the door glass edge.
(Looks like you have plenty of room at the adjustment slot to move the quarter glass forward.
HTH,
Rick
Re: Is this much qtr window misalignment "normal" [Re: RestoRick] #230018
02/23/09 01:21 PM
02/23/09 01:21 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
Thanks the top is the next step...
I just wanted to know if it looked OK - before adding more stuff to the mix...
I think the complete door glass is "crooked" it does not match the windshield - I think this will help kick the back side down...
My concern was I was way off (like something hooked up wrong) and I would rather mess with the glass now then later...
Re: Is this much qtr window misalignment "normal" [Re: 6T6Cuda] #230019
02/23/09 07:36 PM
02/23/09 07:36 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The difference in the convertible and hardtop glass is only about 1/8". The glass is cut about 8" from the back end and angles down that eight inch. It does look like the glass is not square. Is that the original glass you are using?
JB Rhinehart, Realist
A-Body's RULE!
