edelbrock 800 cfm carburetor users
#2299266
05/05/17 12:06 AM
05/05/17 12:06 AM
Posts: 304 Enfield, Ct
Moe
Enfield, Ct
a Dozen calls to their tech line, bigger 'Squirter', Drill out squirter. All still no good. Still have the Off Idle Stumble or lean spot coming off of the idle circuit to the cruise mode.
Do the Eddy 650's have this same trouble?
All linkage is set-up for an Eddy. So it best to try another one.
Re: edelbrock 800 cfm carburetor users
[Re: Moe]
#2299277
05/05/17 12:26 AM
05/05/17 12:26 AM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
I think that strip kit, or whatever they call it might be needed. I had a stumble that was hot or cold, pump shot made no difference, so I made a temporary fix by stretching the springs under both metering rod pistons by just shy of 1/8". That's not the correct fix but it's been there a year now and it drives 99 percent better. It's a vacuum signal thing, 500" 400 block with that 528" solid mopar cam.
[Re: Belvedere1]
#2299295
05/05/17 12:47 AM
05/05/17 12:47 AM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
Which hole is the acc pump arm in? Use the top hole. I did a rod and jet change (7147 rod,.116 pri jet,.110 sec jet, raised the float level (5/16) , orange spring, idle screws 2 1/2 turns out.
I have zero flat spots but I do still have a metering rod issue where they bounce up and down at idle when the engine is warm. Switch to the lower springs. Kinda like changing the power valve in a Holley.
Abe Lincoln
[Re: Belvedere1]
#2299312
05/05/17 01:21 AM
05/05/17 01:21 AM
RapidRobert
recheck the float level (may need to experiment richer) & yes get the strip kit. No vac leak? ported or manifold?
[Re: Moe]
#2299843
05/06/17 12:05 AM
05/06/17 12:05 AM
Posts: 15,526 Omaha Ne
TJP
Omaha Ne
Step #1. What is the inital timing ? Step #2. If you are using the vaccum advance, which port is it hooked up to ?? Step #3, what is your timing doing (mechanical and vacuum) when you increase the RPM ? Step #4 When warm, off choke etc. Where are the throttle blades with respect to the off idle transfer ports / slots ?
[Re: Moe]
#2299939
05/06/17 08:58 AM
05/06/17 08:58 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Moe, There's some good advice above on how to figure this out. What may help you sift it out is that the carb is NOT coming off the idle circuit when the throttle is cracked open. The off-idle gets more fuel from the transfer ports or slots, but is also fed by the idle circuit. This is why people have posted questions about idle-mix screw sensitivity, timing and throttle position. Chrysler Tech has a decent explanation Carburetion Fundamentals and Facts, 1970 MTSC, p7 Full index Master Technicians Service Conference The idle system responds relatively slowly to changes in manifold pressure. If it stumbles when the throttle is gently opened, then its not likely to be solved with more pump shot. If it only stumbles when the throttle is applied quickly, then its pump shot. A smaller throttle and venturi (ie a 650) will be easier to tune the idle system. All things being equal, manifold pressure will be higher and main systems will start earlier. It may give up power at the top (quarter mile) depending on displacement and rpm.
[Re: Moe]
#2300441
05/07/17 12:17 AM
05/07/17 12:17 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Edelbrock calls it a calibration kit, not a strip kit.
[url=Here at summit]http://www.summitracing.com/search/brand/edelbrock/department/air-fuel-delivery/section/carburetors-accessories/part-type/carburetor-calibration-kits?N=400065%2B4294951509%2B4294949628%2B4294921314[/url]
[Re: Moe]
#2334331
07/09/17 09:25 PM
07/09/17 09:25 PM
RapidRobert
that's great. enjoy. (K.I.S.S. sure works)
[Re: Mopar1970440]
#2334333
07/09/17 09:31 PM
07/09/17 09:31 PM
Moe
Enfield, Ct
anyone try one of Thompson performance power blast plates yet? Thinking about putting one on my carb when I get my truck running again. Just saw this. It peaked my interest http://www.thompsonperformance.com/
