edelbrock 800 cfm carburetor users #2299266
05/05/17 12:06 AM
05/05/17 12:06 AM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
a Dozen calls to their tech line, bigger 'Squirter', Drill out squirter. All still no good. Still have the Off Idle Stumble or lean spot coming off of the idle circuit to the cruise mode.
Do the Eddy 650's have this same trouble?
All linkage is set-up for an Eddy. So it best to try another one.
Re: edelbrock 800 cfm carburetor users [Re: Moe] #2299277
05/05/17 12:26 AM
05/05/17 12:26 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I think that strip kit, or whatever they call it might be needed. I had a stumble that was hot or cold, pump shot made no difference, so I made a temporary fix by stretching the springs under both metering rod pistons by just shy of 1/8". That's not the correct fix but it's been there a year now and it drives 99 percent better. It's a vacuum signal thing, 500" 400 block with that 528" solid mopar cam.
Re: edelbrock 800 cfm carburetor users [Re: Moe] #2299280
05/05/17 12:32 AM
05/05/17 12:32 AM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Springs and metering rods took care of mine. Of course it's just a real mild 383.
Re: edelbrock 800 cfm carburetor users [Re: Moe] #2299292
05/05/17 12:44 AM
05/05/17 12:44 AM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
Which hole is the acc pump arm in? Use the top hole. I did a rod and jet change (7147 rod,.116 pri jet,.110 sec jet, raised the float level (5/16) , orange spring, idle screws 2 1/2 turns out.
I have zero flat spots but I do still have a metering rod issue where they bounce up and down at idle when the engine is warm.
Re: edelbrock 800 cfm carburetor users [Re: Belvedere1] #2299295
05/05/17 12:47 AM
05/05/17 12:47 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Switch to the lower springs. Kinda like changing the power valve in a Holley.
Abe Lincoln
Re: edelbrock 800 cfm carburetor users [Re: dart4forte] #2299306
05/05/17 01:07 AM
05/05/17 01:07 AM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
I tried the one step lower (yellow I think) than the orange and ended up going back to the orange for the best of the rough idle I have been able to tune so far.
Re: edelbrock 800 cfm carburetor users [Re: Belvedere1] #2299312
05/05/17 01:21 AM
05/05/17 01:21 AM
recheck the float level (may need to experiment richer) & yes get the strip kit. No vac leak? ported or manifold?
Re: edelbrock 800 cfm carburetor users [Re: Moe] #2299382
05/05/17 08:34 AM
05/05/17 08:34 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
an off line stumble will probably need the idle feed restriction opened, assuming everything else is right.
If you don't have 15° to 20° initial timing, try that. Then try opening the idle mixture screws a bunch just to see if that makes a difference. If either or both of those help, you know what to do.
Re: edelbrock 800 cfm carburetor users [Re: 1E2C] #2299390
05/05/17 09:54 AM
05/05/17 09:54 AM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
iagree Had the same experience but mine is slightly more lumpy over stock.
Re: edelbrock 800 cfm carburetor users [Re: Moe] #2299482
05/05/17 12:32 PM
05/05/17 12:32 PM
usa
Mopar1970440 Offline
usa
anyone try one of Thompson performance power blast plates yet? Thinking about putting one on my carb when I get my truck running again.
Re: edelbrock 800 cfm carburetor users [Re: Moe] #2299843
05/06/17 12:05 AM
05/06/17 12:05 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Step #1. What is the inital timing ?
Step #2. If you are using the vaccum advance, which port is it hooked up to ??
Step #3, what is your timing doing (mechanical and vacuum) when you increase the RPM ?
Step #4
When warm, off choke etc.
Where are the throttle blades with respect to the off idle transfer ports / slots ?
whistling twocents
Re: edelbrock 800 cfm carburetor users [Re: Moe] #2299925
05/06/17 07:11 AM
05/06/17 07:11 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine run 7/32" float level instead of 7/16". Tip in stumble will usually like the accelerator pump rod closest to the choke horn. Stiffer metering springs will bring the enrichment circuit in earlier. The idle cal is pretty forgiving if the throttle plates are open no more than 1-1 1/2 turns of the speed screw. My race car idles fine with a 285@.050" cam.
Doug
Re: edelbrock 800 cfm carburetor users [Re: Moe] #2299939
05/06/17 08:58 AM
05/06/17 08:58 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Moe, There's some good advice above on how to figure this out.
What may help you sift it out is that the carb is NOT coming off the idle circuit when the throttle is cracked open. The off-idle gets more fuel from the transfer ports or slots, but is also fed by the idle circuit.
This is why people have posted questions about idle-mix screw sensitivity, timing and throttle position.
Chrysler Tech has a decent explanation Carburetion Fundamentals and Facts, 1970 MTSC, p7
Full index Master Technicians Service Conference
The idle system responds relatively slowly to changes in manifold pressure. If it stumbles when the throttle is gently opened, then its not likely to be solved with more pump shot. If it only stumbles when the throttle is applied quickly, then its pump shot.
A smaller throttle and venturi (ie a 650) will be easier to tune the idle system. All things being equal, manifold pressure will be higher and main systems will start earlier. It may give up power at the top (quarter mile) depending on displacement and rpm.
Re: edelbrock 800 cfm carburetor users [Re: Moe] #2300429
05/07/17 12:06 AM
05/07/17 12:06 AM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
Thanks guys for the GREAT tips! Can't locate an Eddy Strip Kit Only individual metering rods ect.
Re: edelbrock 800 cfm carburetor users [Re: Moe] #2300441
05/07/17 12:17 AM
05/07/17 12:17 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Edelbrock calls it a calibration kit, not a strip kit.
[url=Here at summit]http://www.summitracing.com/search/brand/edelbrock/department/air-fuel-delivery/section/carburetors-accessories/part-type/carburetor-calibration-kits?N=400065%2B4294951509%2B4294949628%2B4294921314[/url]
Don't be the exception.
Re: edelbrock 800 cfm carburetor users [Re: Moe] #2303620
05/12/17 11:43 PM
05/12/17 11:43 PM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
Thanks guys I am gonna try the Eddy 650 cfm carb
Re: edelbrock 800 cfm carburetor users [Re: Moe] #2334323
07/09/17 09:14 PM
07/09/17 09:14 PM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
Hey Guys,
Just a follow-up
Installed a Eddy 650 in place of the Eddy 800.
"Pump Shot" had EVERYTHING to do w/ off-idle stumble.
Car runs like a champ now.
Will pull a plug soon.
Re: edelbrock 800 cfm carburetor users [Re: Moe] #2334331
07/09/17 09:25 PM
07/09/17 09:25 PM
that's great. enjoy. (K.I.S.S. sure works)
Re: edelbrock 800 cfm carburetor users [Re: Mopar1970440] #2334333
07/09/17 09:31 PM
07/09/17 09:31 PM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
Just saw this. It peaked my interest
http://www.thompsonperformance.com/
