Spark Plug Heat Range: Iron VS Alum Heads #2298564
05/03/17 11:12 PM
05/03/17 11:12 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
If a good heat range on a iron head combo was a NGK7, then an aluminum head replaced the iron head with the same cc, same compression, same cam, would the heat range of the plug need to be hotter for the aluminum head?
If so, what would be a new suggested heat range be for the alum head?
Re: Spark Plug Heat Range: Iron VS Alum Heads [Re: YO7_A66] #2298578
05/03/17 11:36 PM
05/03/17 11:36 PM
I would try the same plugs, if they will fit into both heads properly, if not I would use the same heat range, brand and type, protruded or retracted gap in the new heads thumbs It is way safer IMO to use to cold of a plug instead of to hot of one work
Re: Spark Plug Heat Range: Iron VS Alum Heads [Re: Cab_Burge] #2298592
05/03/17 11:49 PM
05/03/17 11:49 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Cab,
My assumption is that since the iron heads holds more heat which caused me to use a colder plug, that the aluminum plug would need to be hotter.
Thanks Cab!
Re: Spark Plug Heat Range: Iron VS Alum Heads [Re: YO7_A66] #2298975
05/04/17 04:20 PM
05/04/17 04:20 PM
dogdays Offline
dogdays  Offline
One heat range cooler for iron heads.
I went to the only place I was sure there was the same engine with different material heads, early '90s Chevrolet. I figured I'd debunk your theory.
The Camaro 5.7 has aluminum heads,the Caprice 5.7 has iron heads. To my surprise, they had different plugs for each, the plugs were one step cooler for iron heads, or saying it another way, aluminum heads needed one step hotter plug.
So good deduction, at least on a chevy 5.7.
R.
Re: Spark Plug Heat Range: Iron VS Alum Heads [Re: dogdays] #2299006
05/04/17 05:09 PM
05/04/17 05:09 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Thank you DD!!!! Great info!!
