If a good heat range on a iron head combo was a NGK7, then an aluminum head replaced the iron head with the same cc, same compression, same cam, would the heat range of the plug need to be hotter for the aluminum head?
If so, what would be a new suggested heat range be for the alum head?
1970 YO7 A66 [Canadian Export] F8 Challenger
340 (Currently in shop for stroker assy.)
