How much larger is a Duster than a 66 Barracuda #2295918
04/29/17 02:50 AM
04/29/17 02:50 AM
Shopping @ HoBo Fright
340SIX Offline OP
Doc Flappergas's Evil Twin
340SIX  Offline OP
I know the wheel base is. But what about the body, looks close?
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: How much larger is a Duster than a 66 Barracuda [Re: 340SIX] #2295940
04/29/17 05:44 AM
04/29/17 05:44 AM
places
79powerwagon Offline
places
A body vs A body. Other than comfort and safety differences, not very much difference.
Re: How much larger is a Duster than a 66 Barracuda [Re: 340SIX] #2296042
04/29/17 12:53 PM
04/29/17 12:53 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Later A bodies are a bit wider
I own a 65 Cuda, but I have never owned a Duster/Demon so I dunno the specifics.
Don't be the exception.
Re: How much larger is a Duster than a 66 Barracuda [Re: 79powerwagon] #2296046
04/29/17 12:56 PM
04/29/17 12:56 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
1970 Duster is a little larger than a 1966 Barracuda.
Wheelbase- +2"
OAL- same
Width- +1"
Front track- +1"
Width between front frame rails- it was 10 years ago when I compared my '66 V100 to my '68 V200 so I can't recall, it's either +1.5"(most likely correct) or +3"(1.5" per side)
Weight- compared to a '70 Duster, '66 Barracuda about 50 lbs more, a '66 Valiant would be about 50 lbs less
compared to a '73-up Duster would be about the same as a '66 Barracuda
Re: How much larger is a Duster than a 66 Barracuda [Re: 340SIX] #2296048
04/29/17 12:59 PM
04/29/17 12:59 PM
340SIX Offline OP
340SIX  Offline OP
Was late when I posted the Question and forgot to add it is outside body size I am looking at. I know wheel base is shorter on the early A.
To me a car cover from a 66 Barracuda Fast Back should fit a Duster but web sites say no. Friend has one but lives far away so hate to have it sent and not fit a 1970 Up Duster, Dart Sport, Demon.
Re: How much larger is a Duster than a 66 Barracuda [Re: 340SIX] #2296050
04/29/17 01:00 PM
04/29/17 01:00 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Look at the "dealership data books" on hamtramck historical. There will be a page for "Basic Dimensions" in each 66 Barracuda and 70 Duster book.
The factory was good about length width specs on the cars. You will get exact tip to tip spec diagram.
70-74 cars
http://www.hamtramck-historical.com/library.shtml
For 65-69 cars
http://www.hamtramck-historical.com/library-2.shtml
Re: How much larger is a Duster than a 66 Barracuda [Re: 340SIX] #2296060
04/29/17 01:15 PM
04/29/17 01:15 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
That said. I'm sure a 74 duster car cover will fit over a 66 Barracuda. A form fited California Car Cover for a 66 Barracuda will fit more snug in certain areas. But a 74 Duster will fit pretty good since it's a little bigger everywhere and has a fastback like roofline.
Re: How much larger is a Duster than a 66 Barracuda [Re: autoxcuda] #2296089
04/29/17 01:57 PM
04/29/17 01:57 PM
340SIX Offline OP
340SIX  Offline OP
I was 100% sure of that but was wondering the pther way around the smaller Cuda cover on the larger Duster
Re: How much larger is a Duster than a 66 Barracuda [Re: 340SIX] #2296172
04/29/17 06:05 PM
04/29/17 06:05 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
So did you look up the width length and height dimensions from the factory info on Barry's site?
Re: How much larger is a Duster than a 66 Barracuda [Re: autoxcuda] #2296230
04/29/17 09:21 PM
04/29/17 09:21 PM
340SIX Offline OP
340SIX  Offline OP
Yes I tried. Do not know what page to look at looked and looked before posting here.
Looked at AMA specs ect sill weeding threw it.
Thus wanted to ask here. Figured smome one with all the guys here {and few gals} someone would say a duster demom ect is X amount longer wider ect or so close it does not matter
Re: How much larger is a Duster than a 66 Barracuda [Re: 340SIX] #2296250
04/29/17 10:12 PM
04/29/17 10:12 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Re: How much larger is a Duster than a 66 Barracuda [Re: 340SIX] #2296261
04/29/17 10:36 PM
04/29/17 10:36 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Re: How much larger is a Duster than a 66 Barracuda [Re: 340SIX] #2296270
04/29/17 10:45 PM
04/29/17 10:45 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
All that said then 70 doesn't have deminsions. Must have been too new of a car.
Here are the 71 Duster (same) specs:
Here's the 66 Barracuda numbers:
Re: How much larger is a Duster than a 66 Barracuda [Re: autoxcuda] #2296955
05/01/17 02:32 AM
05/01/17 02:32 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Having had a 65 Barracuda and a 71 Duster, I'm not sure how all the numbers compared, but I would think a form fitting Barracuda cover is not going to fit a Duster very well.
Its going to get pretty tight around the roof area. The roof line on the Duster is wider and more squared, while the Barracuda was more narrow and more rounded, especially at the rear window area.
If the cover was not so form fitting, then the Barracuda cover might fit the Duster OK, but I still think it will be pretty tight. Gene
Re: How much larger is a Duster than a 66 Barracuda [Re: 340SIX] #2298367
05/03/17 04:17 PM
05/03/17 04:17 PM
340SIX Offline OP
340SIX  Offline OP
I called the maker of the cover. thet said the 1966 Cuda is made same height and widt. But is made 183.00" long and the Duster is 187.5
but had some extra flannel, left over, heavier than they normally use. From a special order. So made up some in a few lengths with no mirror pockets. AS SEMI CUSTOMS.
And would send one at 100 bucks.
Re: How much larger is a Duster than a 66 Barracuda [Re: 340SIX] #2298420
05/03/17 06:22 PM
05/03/17 06:22 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Was that California car cover or Covercraft?
Re: How much larger is a Duster than a 66 Barracuda [Re: 340SIX] #2298474
05/03/17 08:18 PM
05/03/17 08:18 PM
340SIX Offline OP
340SIX  Offline OP
Since the 1966 Barracuda one was going ti be to short. I was gonna get a Dust Top from California or Covercraft. But the close out store at Covercraft had some soft ones they just made up.
I am putting a California outdoor Noah on top it. I have that on now. But would like the indoor. As I do leave the door open at times and we get rain.
So I will have a nice soft indoor to keep car dust / dirt free as I can. And if It get bumped into. And the outdoor Cali one. So the guy next to me can blow grass, dirt, and leaves etc. on it.
Was 90 bucks plus ship. In a thicker material than Dust Top, think it is flannel? So think that was the best move
Re: How much larger is a Duster than a 66 Barracuda [Re: 340SIX] #2298695
05/04/17 02:49 AM
05/04/17 02:49 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Was it technolon ? It's got perforated little squared in it.
I need to go over there and get in for my brothers mustang. The one you mention will fit his car.
Did you get it at the cover craft outlet: 21414 Parthenia St Canoga Park, CA 91304 ??
Re: How much larger is a Duster than a 66 Barracuda [Re: autoxcuda] #2298816
05/04/17 12:08 PM
05/04/17 12:08 PM
340SIX Offline OP
340SIX  Offline OP
Since the 1966 Barracuda one was going to be to short. I was gonna get a Dust Top from California or Covercraft. But the close out store at Covercraft had some soft ones they just made up.
It was the CoverCraft Outlet store they just have one in Oklahoma and one in California! 95% sure that was the address in I think same local in California. Was transferred on phone there to Outlet store from main place. So not 100% sure. Patti the lady that deals in overruns and blemished. Is out on vacation this week and a guy helped me. These Polycotton , Fannel and Noah were not even put up yet. Just in from Factory.
They had some Noah in that both sizes.
They put them in store and on Ebay As "Blemished" or "Over Runs" panel color may not match, Or special color runs that they have extra material so run it till gone. As over runs. Real savings there but only 30 day warranty. Said no tears ect should be 100% just a Blemish or off color. Or even just a non standard material or color
This is the main # 1-800-382-3040 it may not get ya right there as that lady's calls are forwarded while she is out. {ie} ya may get passed around till ya get the right person
Re: How much larger is a Duster than a 66 Barracuda [Re: 340SIX] #2298927
05/04/17 03:14 PM
05/04/17 03:14 PM
Alberta
4mulaS Offline
4mulaS  Offline
Alberta
I've both cars and the duster sure feels a lot wider than the b cuda
66Scar
