Which Brake Fluid Do I Use?
#2298044
05/03/17 12:57 AM
05/03/17 12:57 AM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
My brake system is all brand new minus the distribution block. 11.75" disks E body front calipers Willwood perportioning valve B van lightweight master cylinder with MP firewall adapter 10" rear drums Right Stuff lines everywhere
Which DOT fluid do I use?
I’m listening.
Re: Which Brake Fluid Do I Use?
[Re: Big Bad Bee]
#2298089
05/03/17 02:01 AM
05/03/17 02:01 AM
RapidRobert
there has been some real informative threads on this, you might see if you can retrieve em (I cant figure it out to save my a$$) & I would Google it, something will come up.
[Re: BDW]
#2298171
05/03/17 10:29 AM
05/03/17 10:29 AM
Posts: 2,592 None
71rm23
None
[Re: Big Bad Bee]
#2298184
05/03/17 11:16 AM
05/03/17 11:16 AM
Posts: 12,070 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Have only used DOT5 in all my Mopars for 20+ years now with no problems. Rockauto has the best price if you are ordering other stuff anyway.
Master, again and still
[Re: minivan]
#2298226
05/03/17 12:16 PM
05/03/17 12:16 PM
Posts: 892 MA
steve70
MA
Dot 5 or face the possibility of damage to paint
1970 Challenger T/A 4 speed
[Re: steve70]
#2298253
05/03/17 12:56 PM
05/03/17 12:56 PM
RapidRobert
Asked & answered (& unamimous!)
[Re: RapidRobert]
#2298258
05/03/17 01:12 PM
05/03/17 01:12 PM
Big Bad Bee
Spokane Valley, WA
Perfect! That's what I was going to GUESS... But nothing like getting the dope from the Moparts faithful. Thank you!
I’m listening.
[Re: Big Bad Bee]
#2299279
05/05/17 12:32 AM
05/05/17 12:32 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Despite all the "OMG never mix them and any part that's ever had DOT X can never touch DOT Y fluid" that is sure to start now, they are fully compatible! In fact if you're going from 5 (silicone) to 3 (glycol) fluid, any water that may have collected in the low spots (because it doesn't mix with the silicone fluid) will likely be absorbed and flushed out by the glycol (which is hygroscopic). It's more important to get the system as dry as possible when going from 3/4 to 5, and for the opposite reason. Edited for "compatible", not "miscible". The two fluids do not, in fact, mix except that the glycol fluid (or maybe the water suspended in it) leaches the purple dye out of the silicone fluid.
[Re: frank]
#2300083
05/06/17 01:36 PM
05/06/17 01:36 PM
RapidRobert
If I may piggyback on this post, to change over to DOT 5 from DOT 3 would that just be a thorough bleed of the MC and lines? Another vote for 5, but 3 is in my car now. Just me If you are sealed up now I would keep it as is. Charles thanks for the heads up on the slave cyl as I have one (not a Howe) but I will avoid dot 5. I likely would not have used it but now for sure I will avoid it (on that app for sure).
[Re: frank]
#2300701
05/07/17 02:42 PM
05/07/17 02:42 PM
Posts: 2,592 None
71rm23
None
If I may piggyback on this post, to change over to DOT 5 from DOT 3 would that just be a thorough bleed of the MC and lines? Another vote for 5, but 3 is in my car now. IMHO, if going to switch, change EVERYTHING. Just so nothing is contaminated, etc, etc,etc. Not to mention all of the headaches.
