Which Brake Fluid Do I Use? #2298044
05/03/17 12:57 AM
05/03/17 12:57 AM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
My brake system is all brand new minus the distribution block.
11.75" disks
E body front calipers
Willwood perportioning valve
B van lightweight master cylinder with MP firewall adapter
10" rear drums
Right Stuff lines everywhere
Which DOT fluid do I use?
I’m listening.
Re: Which Brake Fluid Do I Use? [Re: Big Bad Bee] #2298089
05/03/17 02:01 AM
05/03/17 02:01 AM
there has been some real informative threads on this, you might see if you can retrieve em (I cant figure it out to save my a$$) & I would Google it, something will come up.
Re: Which Brake Fluid Do I Use? [Re: Big Bad Bee] #2298145
05/03/17 08:09 AM
05/03/17 08:09 AM
BDW Offline
BDW  Offline
Dot 5 Silicone
Re: Which Brake Fluid Do I Use? [Re: BDW] #2298171
05/03/17 10:29 AM
05/03/17 10:29 AM
None
71rm23 Offline
71rm23  Offline
None
Originally Posted By cnxt
Dot 5 Silicone
X2
Re: Which Brake Fluid Do I Use? [Re: Big Bad Bee] #2298175
05/03/17 10:56 AM
05/03/17 10:56 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Dot five for me too.
Re: Which Brake Fluid Do I Use? [Re: Big Bad Bee] #2298184
05/03/17 11:16 AM
05/03/17 11:16 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Have only used DOT5 in all my Mopars for 20+ years now with no problems. Rockauto has the best price if you are ordering other stuff anyway.
Master, again and still
Re: Which Brake Fluid Do I Use? [Re: 71rm23] #2298210
05/03/17 11:59 AM
05/03/17 11:59 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Dot 5 Silicone
X2
Only way to go..
Re: Which Brake Fluid Do I Use? [Re: minivan] #2298226
05/03/17 12:16 PM
05/03/17 12:16 PM
MA
steve70 Offline
steve70  Offline
MA
Dot 5 or face the possibility of damage to paint
1970 Challenger T/A 4 speed
Re: Which Brake Fluid Do I Use? [Re: steve70] #2298253
05/03/17 12:56 PM
05/03/17 12:56 PM
Asked & answered (& unamimous!)
Re: Which Brake Fluid Do I Use? [Re: RapidRobert] #2298258
05/03/17 01:12 PM
05/03/17 01:12 PM
Spokane Valley, WA
Spokane Valley, WA
Perfect! That's what I was going to GUESS... But nothing like getting the dope from the Moparts faithful.
Thank you!
I’m listening.
Re: Which Brake Fluid Do I Use? [Re: Big Bad Bee] #2298597
05/03/17 11:52 PM
05/03/17 11:52 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
For what it's worth DOT 5 is not recommended for much of any racing application. It's boiling point is quite a bit lower than DOT 4...but for a classic car, avoiding the risk of substantial paint damage typically overcomes that recommendation.
I will likely use DOT 5, I doubt I'll have any issues with it while autocrossing.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Which Brake Fluid Do I Use? [Re: Big Bad Bee] #2299261
05/04/17 11:56 PM
05/04/17 11:56 PM
tucson az
frank Offline
frank  Offline
tucson az
If I may piggyback on this post, to change over to DOT 5 from DOT 3 would that just be a thorough bleed of the MC and lines? Another vote for 5, but 3 is in my car now.
Re: Which Brake Fluid Do I Use? [Re: Big Bad Bee] #2299279
05/05/17 12:32 AM
05/05/17 12:32 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
popcorn
Despite all the "OMG never mix them and any part that's ever had DOT X can never touch DOT Y fluid" that is sure to start now, they are fully compatible!
In fact if you're going from 5 (silicone) to 3 (glycol) fluid, any water that may have collected in the low spots (because it doesn't mix with the silicone fluid) will likely be absorbed and flushed out by the glycol (which is hygroscopic).
It's more important to get the system as dry as possible when going from 3/4 to 5, and for the opposite reason.
Edited for "compatible", not "miscible". The two fluids do not, in fact, mix except that the glycol fluid (or maybe the water suspended in it) leaches the purple dye out of the silicone fluid.
Re: Which Brake Fluid Do I Use? [Re: Big Bad Bee] #2299359
05/05/17 04:58 AM
05/05/17 04:58 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Since you are not using Willwood calipers DOT 5 is the way to go
Re: Which Brake Fluid Do I Use? [Re: Big Bad Bee] #2299882
05/06/17 01:53 AM
05/06/17 01:53 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Another word of caution: I have a Howe clutch pull-type slave cylinder and DOT 5 leaked past all the seals. I called Howe and they said "our seals are not compatible with it".
Would have been nice if the instruction sheet had said so! $19 for a rebuild kit, a cup and an o-ring. Then they had the nerve to charge me $14 shipping on something that fits in a $1 first class envelope. I flushed the master and line, put DOT 4 fluid in the clutch system and no problems since.
Still have DOT 5 in the brakes and no leaks anywhere.
Re: Which Brake Fluid Do I Use? [Re: Big Bad Bee] #2299923
05/06/17 07:06 AM
05/06/17 07:06 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My Willwood brakes are on their 2nd drag car. Same calipers I've used since the mid 80's. Always have had and still running Dot 5. Never an issue.
Doug
Re: Which Brake Fluid Do I Use? [Re: Big Bad Bee] #2300007
05/06/17 11:42 AM
05/06/17 11:42 AM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
Dot 3 does a good job for me
Re: Which Brake Fluid Do I Use? [Re: frank] #2300083
05/06/17 01:36 PM
05/06/17 01:36 PM
Just me If you are sealed up now I would keep it as is. Charles thanks for the heads up on the slave cyl as I have one (not a Howe) but I will avoid dot 5. I likely would not have used it but now for sure I will avoid it (on that app for sure).
Re: Which Brake Fluid Do I Use? [Re: frank] #2300701
05/07/17 02:42 PM
05/07/17 02:42 PM
None
71rm23 Offline
71rm23  Offline
None
IMHO, if going to switch, change EVERYTHING. Just so nothing is contaminated, etc, etc,etc. Not to mention all of the headaches.
Re: Which Brake Fluid Do I Use? [Re: Big Bad Bee] #2300723
05/07/17 03:23 PM
05/07/17 03:23 PM
BDW Offline
BDW  Offline
I switched to Dot 5 when I changed over to the 2-bolt MC.
As the guru (Ebooger), advised:
Flush with the Dot 5 till its only purple coming out and you're good to go, it's not overly critical, they can be mixed"
Mine has been solid for 3yrs now.
