More compression for a 408 #229717
02/19/09 01:17 PM
02/19/09 01:17 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
I’m getting ready to select the pistons for my 408 and I had a few questions. If I increased the compression from about 10.5:1 to 12:1 what would be the consequences?
Would there be much of a power gain?
Would a 50/50 pump/race gas work?
Would the car run hotter?
Just trying to get some opinions before I order the slugs.
The rest of the combo is as follows:
408, Air-gap intake, 750 dp
Comp solid roller, XE286R, 248/254 duration and .576/.582 lift
Eddy heads (might be able to get some light port work done $$$)
727, 8” PTC converter, 4.10 gears, 3250 lbs with driver
90% race with some street time.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: More compression for a 408 [Re: FlyFish] #229718
02/19/09 07:01 PM
02/19/09 07:01 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
Re: More compression for a 408 [Re: FlyFish] #229719
02/19/09 07:27 PM
02/19/09 07:27 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
My opinion is: you could run a 50% mix if you have a decent quench height and keep the tune-up reasonable.
Things that would go in your favor:
1) cool air intake
2) thermal coating valves and/or piston crown.
If you do all these you may be able to run pump 93.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: More compression for a 408 [Re: FlyFish] #229720
02/19/09 07:28 PM
02/19/09 07:28 PM
Great White North Werst coast
runya Offline
runya  Offline
I have a 410 W-2 with flat tops and 11.5 compression, 260 @ .050 cam and I need to turn my timing back to 32 to keep it out of detonation. That's with a 8" that stalls to 5000.
We have 94 out of the pump here and are at 3000'.
I know there is a power gain if you can keep the timing at optimal but backing the timing down to run on the street is defeting the purpose of more compression. The cam to me seems a little small for 12:1 compression also.
Re: More compression for a 408 [Re: runya] #229721
02/19/09 08:14 PM
02/19/09 08:14 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
Yea, the cam is a little small for the compression. I picked the cam last fall when I thought I was rebuilding my 360 with the stock crank. Would it not be much of a gain for the headache (and expensive race gas)? Is 10.5 :1 compression enough for larger cams in the future?
Re: More compression for a 408 [Re: FlyFish] #229722
02/19/09 08:24 PM
02/19/09 08:24 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
I would go for the highest compression I could get with flat top pistons. Domes would shroud parts of the chamber requiring more ignition advance, in turn requiring more octane to keep out of detonation.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: More compression for a 408 [Re: fasteddie] #229723
02/19/09 11:18 PM
02/19/09 11:18 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I would up the compression, I have that same cam in a 11:1 440 and it makes great power. That cam likes a good set of heads,ask me how I know.
Re: More compression for a 408 [Re: FlyFish] #229724
02/20/09 08:51 AM
02/20/09 08:51 AM
runya Offline
runya  Offline
I should have said the cam is a little small to run that compression with lower octane fuel, There are several variations of cam timing that help but that should be left up to the pro's. Maybe OU812 will chime in, he spece'd mine and the selection was a sweet match to my combo.
Re: More compression for a 408 [Re: FlyFish] #229725
02/20/09 11:01 AM
02/20/09 11:01 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
The extra 1.5 points of compression will result in about 40+ HP. This isn't just peak HP, though, this is everywhere in the power band. I never had much problem with spending a few more bucks on racing gas since A. you only use about 5 gallons per race and B. I usually had a BUNCH of money in my motor so what's another few bucks for good gas? Don't take this wrong but if spending money on racing gas is a concern maybe you shouldn't be doing this. My street only 416 Challenger has 11.75-1 compression and I mixed it 50/50.
Re: More compression for a 408 [Re: runya] #229726
02/20/09 05:27 PM
02/20/09 05:27 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
He spec'ed a hydraulic roller for my engine and I am real happy with the power output.
Re: More compression for a 408 [Re: BobR] #229727
02/20/09 05:45 PM
02/20/09 05:45 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I agree 100%..compression will make notable difference going from 10.5 to 12 in power, and who cares about gas, if you race it 90% of the time anyhow
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
