C body exhaust manifolds for A body ???
#2295635
04/28/17 02:42 PM
04/28/17 02:42 PM
Posts: 2,533 God's Country Maryland
GODSCOUNTRY340
I've been reading that the left side C body exhaust manifold will work on a big block A body. If true, how close is the match? Thanks
Re: C body exhaust manifolds for A body ???
[Re: GODSCOUNTRY340]
#2295688
04/28/17 05:02 PM
04/28/17 05:02 PM
RapidRobert
No actual exp to share but I think it will fit even with the outlet turned 90 deg on those. www.bigblockdart.com would highly likely have the final word on that.
[Re: elmor353]
#2295774
04/28/17 08:47 PM
04/28/17 08:47 PM
Posts: 43,615 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
The C-Body manifold was used when AAR was making the nice A-Body style manifold, too bad they quit making them. The problem is where the exhaust pipe bolts to the manifold, not too much room. B-Body manifolds will work, depends on which steering column you have, usually grinding on the manifold and steering column is required, or you can buy an A-Body set from me for big bucks!
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2295989
04/29/17 11:26 AM
04/29/17 11:26 AM
GODSCOUNTRY340
The C-Body manifold was used when AAR was making the nice A-Body style manifold, too bad they quit making them. The problem is where the exhaust pipe bolts to the manifold, not too much room. B-Body manifolds will work, depends on which steering column you have, usually grinding on the manifold and steering column is required, or you can buy an A-Body set from me for big bucks! Hey Rhinodart, I hear you give Moparts members half off.
#2296446
04/30/17 11:58 AM
04/30/17 11:58 AM
Posts: 75,089 A Banana Republic near you.
JohnRR
I've been reading that the left side C body exhaust manifold will work on a big block A body. If true, how close is the match? Thanks It should work, from the top it will look like the stock A Body manifold , the head pipe connection though does not line up with the stock head pipe , for that you will have to have a pipe creatively bent and welded up. Cudaman1969 brings up a good point, what engine are you using??? 440 ignore what I posted as the engine is wider, I test fit the drivers side C body manifold on a 383. If you angle cut the C body manifold even on a 383 that would help a little with the bend that is needed on the outlet flange.
#2296449
04/30/17 12:03 PM
04/30/17 12:03 PM
JohnRR
The C-Body manifold was used when AAR was making the nice A-Body style manifold, too bad they quit making them. The problem is where the exhaust pipe bolts to the manifold, not too much room. B-Body manifolds will work, depends on which steering column you have, usually grinding on the manifold and steering column is required, or you can buy an A-Body set from me for big bucks! Hey Rhinodart, I hear you give Moparts members half off. no , that's a 50% mark up
#2297192
05/01/17 03:26 PM
05/01/17 03:26 PM
GODSCOUNTRY340
I found a C body HP (pic) on ebay and it's on it's way. I'm planning on using a B body HP manifold for the right side. I have a friend that has one and told me he'd sell it to me cheap.
