C body exhaust manifolds for A body ??? #2295635
04/28/17 02:42 PM
04/28/17 02:42 PM
God's Country Maryland
GODSCOUNTRY340 Offline OP
I've been reading that the left side C body exhaust manifold will work on a big block A body. If true, how close is the match?
Re: C body exhaust manifolds for A body ??? [Re: GODSCOUNTRY340] #2295688
04/28/17 05:02 PM
04/28/17 05:02 PM
No actual exp to share but I think it will fit even with the outlet turned 90 deg on those. www.bigblockdart.com would highly likely have the final word on that.
Re: C body exhaust manifolds for A body ??? [Re: GODSCOUNTRY340] #2295716
04/28/17 06:19 PM
04/28/17 06:19 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Use B Body manifolds...better flow http://www.bigblockdart.com/techpages/HPman.shtml
Re: C body exhaust manifolds for A body ??? [Re: R/T1968R/T] #2295731
04/28/17 07:11 PM
04/28/17 07:11 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I built a 70 Duster with a 440/auto years back. I used b-body hp manifolds. The only thing I did to make them fit was to shorten the steering column tube about 2 inches to clear the outlet. I used Schumacher mounts and everything fit nice and tidy.
Re: C body exhaust manifolds for A body ??? [Re: elmor353] #2295774
04/28/17 08:47 PM
04/28/17 08:47 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The C-Body manifold was used when AAR was making the nice A-Body style manifold, too bad they quit making them. frown The problem is where the exhaust pipe bolts to the manifold, not too much room. B-Body manifolds will work, depends on which steering column you have, usually grinding on the manifold and steering column is required, or you can buy an A-Body set from me for big bucks! biggrin
JB Rhinehart, Realist
A-Body's RULE!
Re: C body exhaust manifolds for A body ??? [Re: GODSCOUNTRY340] #2295807
04/28/17 10:18 PM
04/28/17 10:18 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I tinkered with it for awhile before finding the correct set for my m-code 440. It was tight so I started taper grinding the face at the lower edge, took off about 1/8-3/16s to nothing at top, cleared steering fine then. One good face cut on a head grinder will clean it up to make a smooth fit. IMO about the same restriction as the original.
Re: C body exhaust manifolds for A body ??? [Re: Rhinodart] #2295989
04/29/17 11:26 AM
04/29/17 11:26 AM
Hey Rhinodart, I hear you give Moparts members half off.
Re: C body exhaust manifolds for A body ??? [Re: GODSCOUNTRY340] #2296152
04/29/17 04:38 PM
04/29/17 04:38 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Re: C body exhaust manifolds for A body ??? [Re: GODSCOUNTRY340] #2296446
04/30/17 11:58 AM
04/30/17 11:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It should work, from the top it will look like the stock A Body manifold , the head pipe connection though does not line up with the stock head pipe , for that you will have to have a pipe creatively bent and welded up.
Cudaman1969 brings up a good point, what engine are you using??? 440 ignore what I posted as the engine is wider, I test fit the drivers side C body manifold on a 383.
If you angle cut the C body manifold even on a 383 that would help a little with the bend that is needed on the outlet flange.
Re: C body exhaust manifolds for A body ??? [Re: GODSCOUNTRY340] #2296449
04/30/17 12:03 PM
04/30/17 12:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
no , that's a 50% mark up wink
Re: C body exhaust manifolds for A body ??? [Re: JohnRR] #2296514
04/30/17 02:02 PM
04/30/17 02:02 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Just 50%? biggrin
A-Body's RULE!
Re: C body exhaust manifolds for A body ??? [Re: GODSCOUNTRY340] #2296738
04/30/17 08:32 PM
04/30/17 08:32 PM
John, it's a '69 'Cuda 383. Thanks for the replies.
Re: C body exhaust manifolds for A body ??? [Re: GODSCOUNTRY340] #2297084
05/01/17 12:50 PM
05/01/17 12:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Do you have the manifold or are you looking for one ? It should work on a low deck.
Re: C body exhaust manifolds for A body ??? [Re: GODSCOUNTRY340] #2297192
05/01/17 03:26 PM
05/01/17 03:26 PM
I found a C body HP (pic) on ebay and it's on it's way. I'm planning on using a B body HP manifold for the right side. I have a friend that has one and told me he'd sell it to me cheap.
