Brett The Man Miller
#2296641
04/30/17 05:40 PM
04/30/17 05:40 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
5.50s in Soup with a converter that was built for a 700hp car :)(spend the $ Brett) Cast intake,1 carb on a 28x10.5 tire NO BARS 8.70 at 155mph. It's safe to say this car in good air with the proper converter will run 50s or 40s.
Re: Brett The Man Miller
[Re: Sammy]
#2296700
04/30/17 07:29 PM
04/30/17 07:29 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I have seen the time slip..and he was off a tenth in 60ft alone... very good first outing for sure...I to believe 8.40s is in his reach... great job...
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: J_BODY]
#2296775
04/30/17 09:32 PM
04/30/17 09:32 PM
WHITEDART
bean town ....Ca
motor size small, 3 spd 904 base, foot brake last I knew Jay forgot to mention fully equipped Streetcar... will somebody post a picture of the sleeper
[Re: fishy340]
#2296787
04/30/17 09:47 PM
04/30/17 09:47 PM
Posts: 17,923 Akron, Ohio
ProSport
Akron, Ohio
Definitely a BadAzz car. He posted an in-car video today, it just screams.
[Re: ProSport]
#2296791
04/30/17 09:54 PM
04/30/17 09:54 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I can't wait to see some of these small blocks in action at Norwalk this year
[Re: scottb]
#2296813
04/30/17 10:22 PM
04/30/17 10:22 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Brad when are you hoping to have your car back out Don't know, was is chassis shop jail for a little over a year. I have it back and waiting for body shop to fit it in. Hope in the fall to make some shake down runs, we will see how long body shop has it.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: scottb]
#2297026
05/01/17 11:17 AM
05/01/17 11:17 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Car is very impressive for sure great job brett
[Re: fast68plymouth]
#2297102
05/01/17 01:20 PM
05/01/17 01:20 PM
Posts: 1,784 PA
W5DART66
PA
Shows 845hp on the Moroso slide rule Run converted for weather like a dyno😉 Air was was not the best. About 2200"
[Re: fishy340]
#2297110
05/01/17 01:35 PM
05/01/17 01:35 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Almost 3 mph seems like a ton to go from 2200 feet to even 500-700 foot which would be considered excellent air in most places
