Vinyl inserts in side mouldings #2288690
04/16/17 11:54 AM
04/16/17 11:54 AM
Wausau Wisconsin USA North Ame...
radiatorman Offline OP
Hi Guys,
So I finally got my blue cars side mouldings back, thanks Chuck!! But now I need to clean the b3 blue vinyl that I need to glue back to them. I tried a little spray cleaner and lacquer thinner but neither work. Anybody out there have someting that works on these so I can get them on my car again??
Thanks,
Bob beer
Re: Vinyl inserts in side mouldings [Re: radiatorman] #2288788
04/16/17 01:39 PM
04/16/17 01:39 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If it's only the backsides you need to clean for adhesion, then I'd use acetone, it'll strip any greases/silicone/etc, do a test area first for any adverse reactions, esp if the molding inserts are dyed
Re: Vinyl inserts in side mouldings [Re: DAYCLONA] #2288799
04/16/17 01:52 PM
04/16/17 01:52 PM
Unfortunately, the front side is stained and the backside is clean! Any ideas for that?
Thanks,
Bob beer
Re: Vinyl inserts in side mouldings [Re: radiatorman] #2289907
04/18/17 08:08 AM
04/18/17 08:08 AM
Anybody out there have any ideas???
Thanks,
Bob
Re: Vinyl inserts in side mouldings [Re: radiatorman] #2289924
04/18/17 10:04 AM
04/18/17 10:04 AM
fargo,nd
fk5hemi Offline
fk5hemi  Offline
fargo,nd
They will probably need to be spray dyed with matching color.
Re: Vinyl inserts in side mouldings [Re: fk5hemi] #2290046
04/18/17 02:16 PM
04/18/17 02:16 PM
Lansing, MI
70gtx440dana Online content
70gtx440dana  Online Content
Lansing, MI
Maybe an SEM product typically used on plastic or vinyl interior parts will work. Maybe worth investigating.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Vinyl inserts in side mouldings [Re: 70gtx440dana] #2290148
04/18/17 06:06 PM
04/18/17 06:06 PM
I kind of figured I would have to go the paint/dye way but would have liked to clean mine if I could before I glued them down. Thanks guys for the input and hopefully somebody chimes in before painting with the magic method to get these things clean!!
Thanks,
Bob beer
Re: Vinyl inserts in side mouldings [Re: radiatorman] #2290151
04/18/17 06:15 PM
04/18/17 06:15 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I wonder if a "magic eraser" would clean them up without hurting the vinyl? Might be worth a try on the back side to see if it affects the vinyl.
Re: Vinyl inserts in side mouldings [Re: burdar] #2290471
04/19/17 10:26 AM
04/19/17 10:26 AM
moparx Offline
moparx  Offline
those Mr. Clean erasers make some impressive claims, but i have never tried them. in fact, i never gave them a thought about using them on automotive stains. it might be worth a try, as they are not expensive.
beer
Re: Vinyl inserts in side mouldings [Re: radiatorman] #2290520
04/19/17 12:24 PM
04/19/17 12:24 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
My bathroom shower floor was looking pretty grungy. I tried cleaning it with some bathroom cleaner but it didn't touch it.(did absolutely nothing) My wife said to use the magic eraser. I was skeptical but gave it a shot. shock shock shock WOW!!! It cleaned it instantly. No hard scrubbing, no special cleaner...just a little water and light pressure. I couldn't believe it. I assumed it would be abrasive but it doesn't feel gritty at all. I would definitely try it on some automotive parts. up
Re: Vinyl inserts in side mouldings [Re: burdar] #2296494
04/30/17 01:29 PM
04/30/17 01:29 PM
And now that I finally got them painted the correct B3 color, the damn things shrunk! They are about 1" too short now and I can't get them stretched back. Maybe if I get them warmed up they will stretch? But by the time I get them glued and stuck down, will they shrink back? Any body out there know where to find that type of vinyl moulding? It is 5/16" by about 3/16" tall.
Thanks,
Bob
