Please show off your W7 W8 W9 valley pans #2291781
04/21/17 09:16 PM
04/21/17 09:16 PM
CA.
RAY1969CARS Offline OP
CA.
Thank you
Re: Please show off your W7 W8 W9 valley pans [Re: RAY1969CARS] #2291822
04/21/17 10:50 PM
04/21/17 10:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry I dont have any pics but I made 2 of them..
a sheet metal one and a billet one
EDIT
You might see it here.. this is the sheet metal
one
wave
Re: Please show off your W7 W8 W9 valley pans [Re: MR_P_BODY] #2296386
04/30/17 06:12 AM
04/30/17 06:12 AM
Silver68RT Offline
Silver68RT  Offline
EDIT
one
wave
Who makes those valve covers? I'd like to get a set for my W9's. I see that Milodon makes a fabricated tall/wide valve cover that would work, but I like the cast one you've got better.
Re: Please show off your W7 W8 W9 valley pans [Re: Silver68RT] #2296440
04/30/17 11:41 AM
04/30/17 11:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
EDIT
one
wave
Those covers are the Mopar cast reverse lip ones.. I milled
the logo and the ribs off to make them smooth and to loose
a little weight
wave
Re: Please show off your W7 W8 W9 valley pans [Re: MR_P_BODY] #2296568
04/30/17 03:08 PM
04/30/17 03:08 PM
Silver68RT Offline
Silver68RT  Offline
EDIT
one
wave
a little weight
wave
Nice job, they look great.
Re: Please show off your W7 W8 W9 valley pans [Re: RAY1969CARS] #2296580
04/30/17 03:37 PM
04/30/17 03:37 PM
Silver68RT Offline
Silver68RT  Offline
Looks like those aren't available anymore. Guess I'll have to go with some fabricated ones.
Re: Please show off your W7 W8 W9 valley pans [Re: Silver68RT] #2296809
04/30/17 10:19 PM
04/30/17 10:19 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
W9 take there own valve cover. Yes a stock one will bolt on but doesn't match up to pan rail. Need to order ones made for w9.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Please show off your W7 W8 W9 valley pans [Re: 1967dartgt] #2296826
04/30/17 10:41 PM
04/30/17 10:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've run W9 covers on w2,w5 and the w9s with no
issues(all reverse lip ones)
wave
Re: Please show off your W7 W8 W9 valley pans [Re: MR_P_BODY] #2296860
04/30/17 11:12 PM
04/30/17 11:12 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
wave
Well there are specific valve covers and gaskets made for w9 heads. There not the same as a factory cover or gasket.
Re: Please show off your W7 W8 W9 valley pans [Re: 1967dartgt] #2297010
05/01/17 10:33 AM
05/01/17 10:33 AM
Silver68RT Offline
Silver68RT  Offline
wave
I thought it was just that you had to run a wide style valve cover / reverse lip, and then trim the lip and the gasket to clear the valve springs.
Do you have a link to the W9 specific ones? I couldn't come up with anything on eBay, Jeg's, Summit, Mancini Racing...
Re: Please show off your W7 W8 W9 valley pans [Re: Silver68RT] #2297043
05/01/17 11:58 AM
05/01/17 11:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
Your correct.. a minor radius near the springs and cut the
gaskets the same... took me about 20 minutes
wave
Re: Please show off your W7 W8 W9 valley pans [Re: RAY1969CARS] #2297127
05/01/17 01:51 PM
05/01/17 01:51 PM
Silver68RT Offline
Silver68RT  Offline
I ordered some Milodon fabricated ones. I don't have valves or valve springs yet, and the valve seats aren't machined. Did you have someone port your heads and all that, or did you do them yourself?
Re: Please show off your W7 W8 W9 valley pans [Re: Silver68RT] #2297166
05/01/17 02:43 PM
05/01/17 02:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I had 2 sets of W-9s.. the first set was done by
Chapman and the other set by Shady Dell.. both were
very close on flow.. and they both set them up
wave
Re: Please show off your W7 W8 W9 valley pans [Re: Silver68RT] #2297987
05/02/17 11:22 PM
05/02/17 11:22 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
wave
Here is the correct gasket for a w9
Re: Please show off your W7 W8 W9 valley pans [Re: RAY1969CARS] #2297989
05/02/17 11:25 PM
05/02/17 11:25 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
The incorrect gasket on a w9, this is a Moroso reusable factory gasket. As you can see the end barely touches and wants to push off when tighten down.
Re: Please show off your W7 W8 W9 valley pans [Re: RAY1969CARS] #2297990
05/02/17 11:26 PM
05/02/17 11:26 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Correct gasket and valve cover.
Re: Please show off your W7 W8 W9 valley pans [Re: RAY1969CARS] #2297994
05/02/17 11:28 PM
05/02/17 11:28 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Correct gasket on fabricated Doug lee factory pattern valve cover.
Re: Please show off your W7 W8 W9 valley pans [Re: RAY1969CARS] #2297996
05/02/17 11:29 PM
05/02/17 11:29 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
How much interference you have with gasket.
Re: Please show off your W7 W8 W9 valley pans [Re: RAY1969CARS] #2297999
05/02/17 11:31 PM
05/02/17 11:31 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
The amount of grinding I did to try and make them work.
Re: Please show off your W7 W8 W9 valley pans [Re: RAY1969CARS] #2298000
05/02/17 11:34 PM
05/02/17 11:34 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
How much the springs rub.
