Re: Gen3 Mopar Performance Intake
[Re: cbusters]
#2296036
04/29/17 12:42 PM
04/29/17 12:42 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
Oh, I remember that issue.
There are two versions of that particular manifold, EFI and carb.
Both versions are (or at least, were) machined for OEM stock 5.7 O ring style gaskets.
About two years after crate engines that used that intake started selling, through customer feedback, MP found certain blends of gas, with the carbureted versions of the intake, would "swell up" the O rings over very long term use.
Subsequent contact with the "intake gasket guy" at Chrysler proper + the OE supplier for the O rings confirmed: They are not intended for long term exposure to liquid gasoline. Short term and vapor is OK.
By then, another crate engine had been released, with the predecessor to the tall DP intake on it. It did not have the O ring machining....That engine had pink fiber gaskets. Spoke with engineer for that program, he knew what the deal was. There were similar 5.7 fiber gaskets set up in the product line "just in case".
At the time it would have been damn near impossible...like an act of Congress....to change the machining on the intake. Requiring a new blueprint, PPAP, and all that "OEM" stuff that most other folks who make intakes don't have to deal with... Chrysler was bankrupt at the time, and the only reasonable solution was to recommend fiber gaskets and leave the machining alone. So that's how it happened.
You actually "can" use the O rings over the short term, and it will run just fine for you, but over time they will break down and swell up...it kind of depends on how often you run it and other factors. Although they were intended for a "dry" manifold, they can handle fuel for awhile.
BTW the big threaded hole in front is where the oil goes, there's no water in a Gen3 intake.
Rich H.
Esse Quam Videri
[Re: cbusters]
#2297328
05/01/17 07:24 PM
05/01/17 07:24 PM
dogdays
Find stock style gaskets made from gasoline resistant material, like FKM. Like this: http://www.rockauto.com/en/moreinfo.php?...478&jsn=478An initial glance shows little out there in the way of flat gaskets. Ask Roadhazard to make you some Superformance gaskets. R.
[Re: cbusters]
#2297388
05/01/17 08:59 PM
05/01/17 08:59 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Cometic has flat gaskets.
Mopar to the bone!!!
[Re: cbusters]
#2297708
05/02/17 01:18 PM
05/02/17 01:18 PM
ZIPPY
S.E. Michigan
Pretty sure P5153757 is the one, but it's been a long time, double check before ordering.
Rich H.
Esse Quam Videri
[Re: cbusters]
#2340284
07/20/17 12:49 PM
07/20/17 12:49 PM
72Swinger
Nebraska
I do not know what size, but im sure one that would work could be sourced. Doubt you would find a factory replacement without it also having an intake under it.
[Re: cbusters]
#2340307
07/20/17 01:19 PM
07/20/17 01:19 PM
ZIPPY
S.E. Michigan
I don't think I kept a copy of the bill of materials for that one. However if memory serves (and it very well be failing miserably so don't hold me to it), I think the oil cap is most likely the same one as used on Ansen/Keith Black/Mopar Performance Gen 2 hemi valve covers. Possibly this one https://www.summitracing.com/parts/dcc-5249949Might want to go to Ansen and see if they will share any dimensions.
Rich H.
Esse Quam Videri
[Re: cbusters]
#2341540
07/22/17 04:54 PM
07/22/17 04:54 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
It appears that the MP cap is the correct one, just discontinued. Now to find one! That looks like the cap S&W and other install on their fab rear-ends. You might want to check with them.
[Re: pittsburghracer]
#2341571
07/22/17 06:03 PM
07/22/17 06:03 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If so type in rearend cap in the search bar for lots of options.
[Re: Supercuda]
#2341622
07/22/17 07:50 PM
07/22/17 07:50 PM
Posts: 2,042 MD
RTSE4ME
MD
