I purchased a P4510581 Mopar Performance intake for my 5.7 swap. This is the single 4150 carb version. I noticed the flange side has grooves cut like it uses o-rings. Gaskets I have found say to use flat gaskets on aluminum intakes and not the factory style with the seals on it. Which is correct? Also how to find an install kit with bolts and water outlet.
