Re: Building a 540 mega block [Re: RoadSkinner] #2295241
04/27/17 08:35 PM
04/27/17 08:35 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Heck yea. That will do the trick. I did the same thing by getting running on my stock block motor then moving to a good block when I felt I had a handle on the thing
Re: Building a 540 mega block [Re: RoadSkinner] #2295263
04/27/17 09:13 PM
04/27/17 09:13 PM
Upper Sandusky, Ohio
RoadSkinner Offline OP
Yeah...I got most of the bugs out of the carb....But need to get the shocks n 4 link set....I grude race...So trying to get it to hook on the street
Re: Building a 540 mega block [Re: RoadSkinner] #2295389
04/28/17 12:26 AM
04/28/17 12:26 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Originally Posted By RoadSkinner
I have the car running now with my stock block 528...Its got an F2 Procharger on it ....Blow thru dominator....It will make the power I need...I just don't wanna break the block....So that's why it's getting the new short block
Yeah that is pushing the limits nervous
1963 Plymouth Max Wedge
1971 Barracuda
Re: Building a 540 mega block [Re: RoadSkinner] #2295519
04/28/17 10:55 AM
04/28/17 10:55 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
I built a similar engine, with a 440 block. Has a 4.500 fueler crank, 7.061" Nascar rods (they are super wide!!) and KB280 hyper pistons, with a rollercam 260 @ 050 and .625 lift. 4 of the rods needed some grinding on the half of the bolthead on one side and all the other cleared. Found out when engine was being assembled and locked when turing over.....I would recommend a really good timing chain or gear drive to avoid interference issues. Good luck!!
Re: Building a 540 mega block [Re: RoadSkinner] #2295606
04/28/17 01:28 PM
04/28/17 01:28 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I've run BME 426 forgings with 4.5" stroke. They've cleared 292@.050"cam in my Mega Block. Minimal clearancing at the bottom of the bore, internal oil pickup is trimmed off
Doug
