Re: 6.1 Crank 6.4 block
[Re: joshking440]
#2294499
04/26/17 02:15 PM
04/26/17 02:15 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Not sure about the crank, I read (on LX Forum I think)that the 09 and newer crank can be used in the older blocks but you have some machine work to do to the snout of the crank. http://www.ebay.com/itm/HEMITRONIX-5-7-a...0465508?vxp=mtrI bought this kit for my 2014, 5.7 haven't used it yet.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: joshking440]
#2297432
05/01/17 10:10 PM
05/01/17 10:10 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I'm building a couple boosted Gen3 performance block based 6.1 engines currently but I recently acquired a new 6.4 block and a drag pak 6.1 based 392 rotating kit as well as a set of cam and lifters real real cheap and new still so I'm weighing the options on the most economical way to finish it. 6.4 block is a lot stronger IMO
