741 case #2294106
04/25/17 09:40 PM
04/25/17 09:40 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
a pic of the 8 3/4 that was on the 69 RR. Had traction bars. Isn't a sure grip - I know anything can happen in the past changing parts - Are there any vin numbers stamped anywhere like the engine and 4 speed ?
68 Satellite Wagon and a few other ones
Re: 741 case [Re: mro] #2294123
04/25/17 09:54 PM
04/25/17 09:54 PM
Mopar assembling lines would use what parts they had as long as the gear ratio was proper for that cars 8 3/4 shruggy
The other thing to keep in mind is who knows what happened to that car before you got it, many Hemi and Max Wedge cars ended up on use car lots with non stock B and LA motors in them shruggy work
Re: 741 case [Re: mro] #2294124
04/25/17 09:55 PM
04/25/17 09:55 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
So its possible they would have had an A31 car without a sure grip or is that the giveaway that the pumpkin has been changed ?
Re: 741 case [Re: mro] #2294128
04/25/17 09:56 PM
04/25/17 09:56 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
By the way - tied into this mornings post about axle tension - this one spins like the 3.55 so I guess I'd better check the bee's 3:91
Re: 741 case [Re: mro] #2294129
04/25/17 09:58 PM
04/25/17 09:58 PM
Not to my knowledge.
Re: 741 case [Re: mro] #2294142
04/25/17 10:21 PM
04/25/17 10:21 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
If the car in question is a 4 spd it would not have a 741 rear.
Re: 741 case [Re: mro] #2294153
04/25/17 10:43 PM
04/25/17 10:43 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
Thanks. What case would have been correct for a 69 3.91 sure grip?
Re: 741 case [Re: mro] #2294155
04/25/17 10:44 PM
04/25/17 10:44 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
It is a 4 speed
Re: 741 case [Re: mro] #2294159
04/25/17 10:50 PM
04/25/17 10:50 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
I had an original '69 RR 383 4-speed 3.23 peg leg. It had a '489 case.
Re: 741 case [Re: mro] #2294165
04/25/17 11:02 PM
04/25/17 11:02 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
the 3:91 sure grip wasn't produced in the 741 ?
Re: 741 case [Re: mro] #2294180
04/25/17 11:22 PM
04/25/17 11:22 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
I have a 741 case with 3:91 sure grip that I pulled out of a van down by the river , actually a van at the local junk yard many moons ago , it's now in my 71 Bee
The factory 489 case with 3:23 sure grip is long gone , wish I still had it
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 741 case [Re: mro] #2294217
04/26/17 12:11 AM
04/26/17 12:11 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Yes it was but most of the ones I have found were in 68 down light duty pickups.
Re: 741 case [Re: mro] #2294220
04/26/17 12:18 AM
04/26/17 12:18 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Same here, '741 housing with 3.91 SG that came out of a pick-up truck chassis...no other details, other than it was a pick-up truck.
Re: 741 case [Re: mro] #2294313
04/26/17 03:31 AM
04/26/17 03:31 AM
My 1969 GTS Dart H code 4 speed car(SPD in 9-68) has the original 741 case 3.91 gears clutch type posi in it still shruggy Never say never work
Re: 741 case [Re: mro] #2294437
04/26/17 12:11 PM
04/26/17 12:11 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Sorry, I have the original pig in my GTS, it's a 741 and it's a 3.91 suregrip.
Abe Lincoln
Re: 741 case [Re: dart4forte] #2294483
04/26/17 01:35 PM
04/26/17 01:35 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have a 741 SG with 3.91s. It's supposedly out of a '69 340 Swinger.
Re: 741 case [Re: slantzilla] #2294497
04/26/17 02:13 PM
04/26/17 02:13 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I had a 69 GTS 340 auto that came with a 489 case and 3.55 suregrip.
Re: 741 case [Re: mro] #2294591
04/26/17 06:01 PM
04/26/17 06:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Pumpkin changed, A31 B body would have had a 489 case, A31 includes SUREGRIP so no it is not possible to have one unless the factory installed the wrong chuck in the housing.
What is the date stamped on the ring gear , an A100 I think could be had with a 3.91 with no sure grip and a 741 case.
Re: 741 case [Re: Cab_Burge] #2294597
04/26/17 06:08 PM
04/26/17 06:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I want to say you got hosed then ??? I am 99.9% sure my May 69 build 383 4 speed GTS has a 489 ...
There is no VIN on any Chrysler rear, only date codes, and BOM on Danas ...
Re: 741 case [Re: JohnRR] #2294712
04/26/17 10:39 PM
04/26/17 10:39 PM
I traded the original owner for that car, I didn't buy it new. He had been a dealership mechanic but he was a flake also, he insisted that the rear end was the original one that came in the car, he had no reason to lie about that work
I didn't say it had any I.D. numbers on it, only that it was a 741 case with a clutch type posi and 3.91 gears in it shruggy
I'm not exactly sure when Mopar started installing the 489 cases and the other Eaton type posi, I know it was sometime in the 1969 production year shruggy
