741 case
#2294106
04/25/17 09:40 PM
04/25/17 09:40 PM
Posts: 1,107 Lynch Road
mro
Lynch Road
a pic of the 8 3/4 that was on the 69 RR. Had traction bars. Isn't a sure grip - I know anything can happen in the past changing parts - Are there any vin numbers stamped anywhere like the engine and 4 speed ?
68 Satellite Wagon and a few other ones
Re: 741 case
[Re: mro]
#2294123
04/25/17 09:54 PM
04/25/17 09:54 PM
Posts: 43,285 Bend,OR USA
Cab_Burge
Mopar assembling lines would use what parts they had as long as the gear ratio was proper for that cars 8 3/4 The other thing to keep in mind is who knows what happened to that car before you got it, many Hemi and Max Wedge cars ended up on use car lots with non stock B and LA motors in them
Re: 741 case
[Re: mro]
#2294124
04/25/17 09:55 PM
04/25/17 09:55 PM
mro
Lynch Road
So its possible they would have had an A31 car without a sure grip or is that the giveaway that the pumpkin has been changed ?
Re: 741 case
[Re: mro]
#2294128
04/25/17 09:56 PM
04/25/17 09:56 PM
mro
Lynch Road
By the way - tied into this mornings post about axle tension - this one spins like the 3.55 so I guess I'd better check the bee's 3:91
Re: 741 case
[Re: mro]
#2294129
04/25/17 09:58 PM
04/25/17 09:58 PM
RapidRobert
Are there any vin numbers stamped anywhere like the engine and 4 speed ? Not to my knowledge.
Re: 741 case
[Re: mro]
#2294153
04/25/17 10:43 PM
04/25/17 10:43 PM
mro
Lynch Road
Thanks. What case would have been correct for a 69 3.91 sure grip?
Re: 741 case
[Re: mro]
#2294165
04/25/17 11:02 PM
04/25/17 11:02 PM
mro
Lynch Road
the 3:91 sure grip wasn't produced in the 741 ?
Re: 741 case
[Re: mro]
#2294180
04/25/17 11:22 PM
04/25/17 11:22 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
I have a 741 case with 3:91 sure grip that I pulled out of a van down by the river , actually a van at the local junk yard many moons ago , it's now in my 71 Bee
The factory 489 case with 3:23 sure grip is long gone , wish I still had it
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
Re: 741 case
[Re: mro]
#2294217
04/26/17 12:11 AM
04/26/17 12:11 AM
Posts: 6,433 Abilene, Texas
fastmark
Abilene, Texas
the 3:91 sure grip wasn't produced in the 741 ? Yes it was but most of the ones I have found were in 68 down light duty pickups.
Re: 741 case
[Re: mro]
#2294437
04/26/17 12:11 PM
04/26/17 12:11 PM
Posts: 16,161 Mesa, Arizona
dart4forte
Mesa, Arizona
the 3:91 sure grip wasn't produced in the 741 ? Sorry, I have the original pig in my GTS, it's a 741 and it's a 3.91 suregrip.
Abe Lincoln
Re: 741 case
[Re: dart4forte]
#2294483
04/26/17 01:35 PM
04/26/17 01:35 PM
Posts: 20,205 Park Forest, IL
slantzilla
Park Forest, IL
the 3:91 sure grip wasn't produced in the 741 ? Sorry, I have the original pig in my GTS, it's a 741 and it's a 3.91 suregrip. I have a 741 SG with 3.91s. It's supposedly out of a '69 340 Swinger.
Re: 741 case
[Re: mro]
#2294591
04/26/17 06:01 PM
04/26/17 06:01 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
So its possible they would have had an A31 car without a sure grip or is that the giveaway that the pumpkin has been changed ? Pumpkin changed, A31 B body would have had a 489 case, A31 includes SUREGRIP so no it is not possible to have one unless the factory installed the wrong chuck in the housing. What is the date stamped on the ring gear , an A100 I think could be had with a 3.91 with no sure grip and a 741 case.
Re: 741 case
[Re: Cab_Burge]
#2294597
04/26/17 06:08 PM
04/26/17 06:08 PM
JohnRR
My 1969 GTS Dart H code 4 speed car(SPD in 9-68) has the original 741 case 3.91 gears clutch type posi in it still Never say never I want to say you got hosed then ??? I am 99.9% sure my May 69 build 383 4 speed GTS has a 489 ... There is no VIN on any Chrysler rear, only date codes, and BOM on Danas ...
Re: 741 case
[Re: JohnRR]
#2294712
04/26/17 10:39 PM
04/26/17 10:39 PM
Cab_Burge
I traded the original owner for that car, I didn't buy it new. He had been a dealership mechanic but he was a flake also, he insisted that the rear end was the original one that came in the car, he had no reason to lie about that I didn't say it had any I.D. numbers on it, only that it was a 741 case with a clutch type posi and 3.91 gears in it I'm not exactly sure when Mopar started installing the 489 cases and the other Eaton type posi, I know it was sometime in the 1969 production year
