Page 1 of 3 1 2 3
what oil are you running in your street big block? #229320
02/18/09 10:56 PM
02/18/09 10:56 PM
CT USA
N
Nick Mineau Offline OP
N
CT USA
im courious
what weight and type of oil are you running in your street big block? what oil pressure?
i run valvoline conventional 10w40 with 30 psi hot idle, 67psi @ 3000
Re: what oil are you running in your street big block? [Re: Nick Mineau] #229321
02/18/09 11:31 PM
02/18/09 11:31 PM
Mid Michigan
Coronet-R/T-Rag Offline
Mid Michigan
I run Shell 15w-40 Rotella diesel oil. You need the Zinc for your cam. Most passenger car oil had the zinc reduced to a potentially dangerous level.
Re: what oil are you running in your street big block? [Re: Nick Mineau] #229322
02/19/09 12:48 AM
02/19/09 12:48 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
MY current ride isnt running yet, but I have always run SAE30.
Re: what oil are you running in your street big block? [Re: Nick Mineau] #229323
02/19/09 01:03 AM
02/19/09 01:03 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Your pressures are good.
I usually run 10w30 in mine.
Occasionally, I will run 15w40, if the weather is unusually hot.
I get similiar pressures to what has been posted.
Re: what oil are you running in your street big block? [Re: Nick Mineau] #229324
02/19/09 01:04 AM
02/19/09 01:04 AM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline
Valvoline 10W30
60 psi at idle, 80 psi at 3000
doesnt usually get below freezing here but its been an unusually cold winter so Ive been careful not to start it below 30 or so
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
71 Country Squire 351W
71 Road Runner 440+6
71 Satellite sedan 318
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
10 Challenger R/T M6
15 Challenger Hellcat M6
Re: what oil are you running in your street big block? [Re: Coronet-R/T-Rag] #229325
02/19/09 09:27 AM
02/19/09 09:27 AM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
And the current Rotella has reduced zinc levels to a point much less than the original.It is no where near the old Rotella.Truck emission standards are being raised by the manufacturer and the oil is being blended to coincide,so don't take it for granted that you are home free.If you are set on diesel oil,Chevron Delo has more zinc than the Rotella.
Re: what oil are you running in your street big block? [Re: I go fast] #229326
02/19/09 09:23 PM
02/19/09 09:23 PM
Mid Michigan
Mid Michigan
I've heard that Rotella has reduced its zinc levels. I've also heard that it still has enough zinc in it to keep a solid lifter cam alive. I've also heard about more than a few cam failures lately with passenger car oil. I'm not defending this oil, I run it because I buy it by the barrell for my big truck. It holds 28 quarts.
Re: what oil are you running in your street big block? [Re: Coronet-R/T-Rag] #229327
02/19/09 09:37 PM
02/19/09 09:37 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
valvoline vr-1 20w50
Re: what oil are you running in your street big block? [Re: Coronet-R/T-Rag] #229328
02/19/09 09:39 PM
02/19/09 09:39 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Just to say, I run Shell Rotella T 5-40 full synthetic. Around 1400 ppm zinc. Nice oil for the street/strip and not too much $$$.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: what oil are you running in your street big block? [Re: I go fast] #229329
02/19/09 10:29 PM
02/19/09 10:29 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Raised "by the manufacturer" ??? Careful there. I work for a major heavy duty truck manufacturer. "WE" are not raising the emission standards. Not saying we don't support them--just clarifying.
Re: what oil are you running in your street big block? [Re: Nick Mineau] #229330
02/19/09 11:31 PM
02/19/09 11:31 PM
I run regular 5W20 Valvoline(non synthetic)in my 518 C.I. stroker, it idles at 50 lbs at 900 rpm cold and 18 to 23 lbs at 900 rpm hot, above 170 F oil temp. I cut the oil pump bypass spring so the oil pressure never exceeds 70 no matter what rpm or oil tempertautre works good, last a long time, three years of drag racing (50 to 100 runs a year, 10:34 ET at 128.6 MPH in a 3400 lb Duster)and less than 1000 miles a year street driving
Re: what oil are you running in your street big block? [Re: Cab_Burge] #229331
02/20/09 06:20 AM
02/20/09 06:20 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I run Castrol 20w50 in my 440. I hav 60lbs at 900rpm but thats also dependent on your HV Oil Pump & how tight your clearances are. I used to run straight 50w in my other 440 because the clearances were a bit looser....
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: what oil are you running in your street big block? [Re: Coronet-R/T-Rag] #229332
02/20/09 06:34 AM
02/20/09 06:34 AM
Big Chicago
amixon Offline
amixon  Offline
Big Chicago
I go to farm and fleet and purchase two cases one for my Diesel and the other for the flat tappet hotrod! The valve train psi in a Diesel engine still require the missing zinc from automotive engine, but if you have a roller cam that changes things a bit
Big Anthony ANTHONYinIRAQ@gmail.com
1984 B150 Ram Wagon
1978 D100 ClubCab
Re: what oil are you running in your street big block? [Re: amixon] #229333
02/20/09 08:37 AM
02/20/09 08:37 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
10-40 Royal Purple Synthetic. Oil pressure pegged. 440.
Re: what oil are you running in your street big block? [Re: Pacnorthcuda] #229334
02/20/09 09:26 AM
02/20/09 09:26 AM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
Sorry,should have said being forced to raise standards.
Re: what oil are you running in your street big block? [Re: I go fast] #229335
02/20/09 01:55 PM
02/20/09 01:55 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
20w-50 Valvoline in my 63. Ron
Re: what oil are you running in your street big block? [Re: 383man] #229336
02/20/09 02:04 PM
02/20/09 02:04 PM
Newark,De
hemi471 Offline
hemi471  Offline
Newark,De
Valvoline VR-1 10W-30 untill break-in then Amsoil
10W-30 Racing oil.
Re: what oil are you running in your street big block? [Re: hemi471] #229337
02/20/09 02:13 PM
02/20/09 02:13 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
10W-30 Racing oil.
Don't want to hi-jack but does the Amsoil syn have any ZDDP and also I've heard the synthetics are more prone to leaking (past gaskets) than Dino oil is.
Re: what oil are you running in your street big block? [Re: Classof70Chally] #229338
02/20/09 02:37 PM
02/20/09 02:37 PM
Newark,De
hemi471 Offline
hemi471  Offline
Newark,De
MAXIMUM DURABILITY, MAXIMUM WEAR PROTECTION
AMSOIL Dominator Synthetic Racing Oil features an additive package heavily fortified with zinc and phosphorus for superior long-term wear protection. Designed for maximum durability, it ensures critical engine components are protected for the duration of the race. Dominator Synthetic Racing Oil’s superior additive technology provides unmatched durability in extreme conditions. In addition, its high levels of zinc and phosphorus additives make it ideal for street rods, muscle cars and other vehicles with flat-tappet cams.
Re: what oil are you running in your street big block? [Re: hemi471] #229339
02/20/09 02:44 PM
02/20/09 02:44 PM
Central NC
gch Offline
gch  Offline
Central NC
Castrol 10w40 with Hughes engines additive.
Page 1 of 3 1 2 3
