1/2" 20 thread 2" long, grade 8 screw in stud adequate? #2292100
04/22/17 02:11 PM
04/22/17 02:11 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
My car has a Dana 60 with aftermarket axles. I run a spool in it and have ET Street Pro Drag Radials. The car gets driven everwhere and raced on average every other weekend or so in the summer.
Are the 1/2" 20 thread studs adequate?
'63 Dodge 330
11.19 @ 121 mph
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate? [Re: GY3] #2292287
04/22/17 07:22 PM
04/22/17 07:22 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
What wheels? If a thick flanged aftermarket wheel, 2 inch long would be on the short side. Better to have a 3 inch long stud. The stud should protrude into the hex portion of the lug nut at least equal to the diameter of the stud. If starting from scratch and planning to go faster later on, A 5/8 inch stud might be a good idea.
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate? [Re: forphorty] #2292333
04/22/17 08:42 PM
04/22/17 08:42 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Stock 15x8 steelies.
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate? [Re: GY3] #2292338
04/22/17 08:51 PM
04/22/17 08:51 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
As log as you're not running thick spacers you should be fine.
- Stu Harmon
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate? [Re: feets] #2292375
04/22/17 10:13 PM
04/22/17 10:13 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
So why is this happening?!
'63 Dodge 330
11.19 @ 121 mph
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate? [Re: GY3] #2292389
04/22/17 10:52 PM
04/22/17 10:52 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
This thread might help
CLICK HERE FOR LINK
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate? [Re: GY3] #2292396
04/22/17 11:08 PM
04/22/17 11:08 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
How can only 2 be bent work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate? [Re: hemi-itis] #2292428
04/22/17 11:55 PM
04/22/17 11:55 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
All on drivers side were bent. These were two randomly picked for pics.
'63 Dodge 330
11.19 @ 121 mph
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate? [Re: GY3] #2292519
04/23/17 02:28 AM
04/23/17 02:28 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Who's studs? Picture of any markings on the head? Probably done on the street on a sharp turn with the spool in it. I've heard of guys breaking stock axles and wheel studs using a spool on the street.
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate? [Re: CMcAllister] #2292524
04/23/17 02:43 AM
04/23/17 02:43 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Dr. Diff supplied with the axles. 6 dashes on the heads.
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate? [Re: GY3] #2292595
04/23/17 10:29 AM
04/23/17 10:29 AM
Palm Coast, FL (near Daytona B...
Blown_Hemi Offline
Blown_Hemi  Offline
Could try some ARP wheel studs.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate? [Re: Blown_Hemi] #2292615
04/23/17 11:25 AM
04/23/17 11:25 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
I already replaced with Strange studs. We'll see how these work..
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate? [Re: CMcAllister] #2292724
04/23/17 02:16 PM
04/23/17 02:16 PM
hemi-itis Offline
hemi-itis  Offline
Not with a Dana!
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate? [Re: Blown_Hemi] #2292748
04/23/17 03:17 PM
04/23/17 03:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I run the 1/2 ARP studs and they are tough...........
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate? [Re: hemi-itis] #2292753
04/23/17 03:25 PM
04/23/17 03:25 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Not with a Dana!
No, not with a Dana, but it does demonstrate the loads put on axles and studs with a spool on the street. Especially with large, sticky tires.
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate? [Re: GY3] #2292878
04/23/17 07:14 PM
04/23/17 07:14 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have had 1 ARP's break off last year. Passenger side, the 4 others were bent. Drivers side were straight. 1/2" x 3 " Why? The nuts were tight, could be that I dump the clutch at 4600 over and over and over . I find no fault with ARP wheel studs . I was going to go to 5/8 but Strange had a problem with re drilling their axles to 5/8 size. The 1/2" ARP studs will tale a lot of abuse if you keep your nuts tight and check the torque before every race.
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate? [Re: rowin4] #2292880
04/23/17 07:22 PM
04/23/17 07:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That just means your giving the RR that little
extra load so the car leaves straight.. if the
pre-load was equal the car would push to the
right.. but you have more pre-load on the right
to compensate for it
wave
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate? [Re: GY3] #2293155
04/24/17 11:39 AM
04/24/17 11:39 AM
an8sec70cuda Offline
FWIW...I've run my car w/ the same 1/2"-20 wheel studs for 13 years and never had a failure. The first 3 years were running mid 10s at 3700 lbs and then 10+ years of mid 9 sec passes at 3800 lbs.
I did finally upgrade to 5/8" studs last year after the car dipped into the 8s on nitrous. All the 1/2" studs are still straight. I think they are ARP but not sure...whatever Moser uses.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate? [Re: GY3] #2293584
04/25/17 12:16 AM
04/25/17 12:16 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
In Dizusters case we found that the stock style steel wheel provides very little surface area against the rotor/drum surface. Even though the clamp load with 1/2 studs may be adequate the surface area is quite a bit smaller. This allows the wheel to slip against the rotor/drum face bending the studs. You either need more surface area or more clamp load.
Doug
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate? [Re: dvw] #2293744
04/25/17 10:58 AM
04/25/17 10:58 AM
moparx Offline
moparx  Offline
Doug
didn't you guys weld in "bungs" of sorts [for lack of a better description] for the studs, or stiffening plates to the back side of the wheels to fix this issue ? or was that after switching over to the 5/8" studs ?
beer
