1/2" 20 thread 2" long, grade 8 screw in stud adequate?
#2292100
04/22/17 02:11 PM
04/22/17 02:11 PM
Posts: 4,669 Wichita
GY3
Wichita
My car has a Dana 60 with aftermarket axles. I run a spool in it and have ET Street Pro Drag Radials. The car gets driven everwhere and raced on average every other weekend or so in the summer.
Are the 1/2" 20 thread studs adequate?
Re: 1/2" 20 thread 2" long, grade 8 screw in stud adequate?
[Re: forphorty]
#2292333
04/22/17 08:42 PM
04/22/17 08:42 PM
GY3
Wichita
[Re: GY3]
#2292338
04/22/17 08:51 PM
04/22/17 08:51 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
As log as you're not running thick spacers you should be fine.
[Re: feets]
#2292375
04/22/17 10:13 PM
04/22/17 10:13 PM
GY3
Wichita
So why is this happening?!
[Re: GY3]
#2292389
04/22/17 10:52 PM
04/22/17 10:52 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
This thread might help CLICK HERE FOR LINK
[Re: hemi-itis]
#2292428
04/22/17 11:55 PM
04/22/17 11:55 PM
GY3
Wichita
How can only 2 be bent All on drivers side were bent. These were two randomly picked for pics.
[Re: GY3]
#2292519
04/23/17 02:28 AM
04/23/17 02:28 AM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Who's studs? Picture of any markings on the head? Probably done on the street on a sharp turn with the spool in it. I've heard of guys breaking stock axles and wheel studs using a spool on the street.
[Re: CMcAllister]
#2292524
04/23/17 02:43 AM
04/23/17 02:43 AM
GY3
Wichita
Who's studs? Picture of any markings on the head? Probably done on the street on a sharp turn with the spool in it. I've heard of guys breaking stock axles and wheel studs using a spool on the street. Dr. Diff supplied with the axles. 6 dashes on the heads.
[Re: Blown_Hemi]
#2292615
04/23/17 11:25 AM
04/23/17 11:25 AM
GY3
Wichita
Could try some ARP wheel studs. I already replaced with Strange studs. We'll see how these work..
[Re: CMcAllister]
#2292724
04/23/17 02:16 PM
04/23/17 02:16 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Who's studs? Picture of any markings on the head? Probably done on the street on a sharp turn with the spool in it. I've heard of guys breaking stock axles and wheel studs using a spool on the street. Not with a Dana!
[Re: Blown_Hemi]
#2292748
04/23/17 03:17 PM
04/23/17 03:17 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Could try some ARP wheel studs. I run the 1/2 ARP studs and they are tough...........
[Re: hemi-itis]
#2292753
04/23/17 03:25 PM
04/23/17 03:25 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Who's studs? Picture of any markings on the head? Probably done on the street on a sharp turn with the spool in it. I've heard of guys breaking stock axles and wheel studs using a spool on the street. Not with a Dana! No, not with a Dana, but it does demonstrate the loads put on axles and studs with a spool on the street. Especially with large, sticky tires.
[Re: GY3]
#2292878
04/23/17 07:14 PM
04/23/17 07:14 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I have had 1 ARP's break off last year. Passenger side, the 4 others were bent. Drivers side were straight. 1/2" x 3 " Why? The nuts were tight, could be that I dump the clutch at 4600 over and over and over . I find no fault with ARP wheel studs . I was going to go to 5/8 but Strange had a problem with re drilling their axles to 5/8 size. The 1/2" ARP studs will tale a lot of abuse if you keep your nuts tight and check the torque before every race.
[Re: rowin4]
#2292880
04/23/17 07:22 PM
04/23/17 07:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have had 1 ARP's break off last year. Passenger side, the 4 others were bent. Drivers side were straight. 1/2" x 3 " Why? The nuts were tight, could be that I dump the clutch at 4600 over and over and over . I find no fault with ARP wheel studs . I was going to go to 5/8 but Strange had a problem with re drilling their axles to 5/8 size. The 1/2" ARP studs will tale a lot of abuse if you keep your nuts tight and check the torque before every race. That just means your giving the RR that little extra load so the car leaves straight.. if the pre-load was equal the car would push to the right.. but you have more pre-load on the right to compensate for it
[Re: GY3]
#2293155
04/24/17 11:39 AM
04/24/17 11:39 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
FWIW...I've run my car w/ the same 1/2"-20 wheel studs for 13 years and never had a failure. The first 3 years were running mid 10s at 3700 lbs and then 10+ years of mid 9 sec passes at 3800 lbs. I did finally upgrade to 5/8" studs last year after the car dipped into the 8s on nitrous. All the 1/2" studs are still straight. I think they are ARP but not sure...whatever Moser uses.
