Small block W7.8.9 intake any one put on w2/w5??? #2291881
04/22/17 12:38 AM
04/22/17 12:38 AM
CA.
RAY1969CARS Offline OP
CA.
Any information would be helpful thank you Mopar or no car
Re: Small block W7.8.9 intake any one put on w2/w5??? [Re: RAY1969CARS] #2291892
04/22/17 01:03 AM
04/22/17 01:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A W7-8-9 uses a dry intake.. meaning it doesnt
have water in it.. W2 and W5 are wet intakes
that have water in a couple of ports.. I have
never tried to put a W7-8-9 on a w2-5.. can it
be done.. yes with some work
EDIT
Also the W-7-8-9 use a valley pan and the W2-5
dont..they have a built in valley pan
wave
Re: Small block W7.8.9 intake any one put on w2/w5??? [Re: MR_P_BODY] #2291894
04/22/17 01:05 AM
04/22/17 01:05 AM
CA.
CA.
Somewhere I remember seeing a W5 build with a W9 intake on the tall deck
Re: Small block W7.8.9 intake any one put on w2/w5??? [Re: RAY1969CARS] #2291896
04/22/17 01:10 AM
04/22/17 01:10 AM
oregon
greendart408 Offline
oregon
Triple threat on here had a tall deck r3 block, and a 420 intake on brodix head.
Re: Small block W7.8.9 intake any one put on w2/w5??? [Re: greendart408] #2291899
04/22/17 01:13 AM
04/22/17 01:13 AM
CA.
CA.
Really I hope he sees this post
Re: Small block W7.8.9 intake any one put on w2/w5??? [Re: RAY1969CARS] #2291905
04/22/17 01:19 AM
04/22/17 01:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Can it be done.. yes.. its just a matter of pluming
in a few water points
wave
Re: Small block W7.8.9 intake any one put on w2/w5??? [Re: MR_P_BODY] #2291918
04/22/17 01:37 AM
04/22/17 01:37 AM
CA.
CA.
That's what I was thinking Cant be too hard should I cross over the block or bring everything to the Remote thermostat housing
Re: Small block W7.8.9 intake any one put on w2/w5??? [Re: RAY1969CARS] #2292310
04/22/17 08:13 PM
04/22/17 08:13 PM
Earth
Rob C Offline
Rob C  Offline
Earth
You'll need to use such a thermo stat housing. Often I see the unit welded at the front of the engine to the valley plate.
Re: Small block W7.8.9 intake any one put on w2/w5??? [Re: RAY1969CARS] #2293196
04/24/17 01:11 PM
04/24/17 01:11 PM
Renton Washington
Triple Threat Offline
Renton Washington
R3 block, Brodix B1-MC heads, Ritter 420 intake. Billet valley tray with a thermostat housing. Heads were welded and tapped for the water lines. I can't claim to have created this, I bought the engine already together. Ran it like this for 3 seasons before a piston let go and I parted it out.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Small block W7.8.9 intake any one put on w2/w5??? [Re: Triple Threat] #2293437
04/24/17 09:04 PM
04/24/17 09:04 PM
CA.
CA.
Right on thanks for the input any leftover parts for sale ? What was the displacement of the motor and was it a tall deck or a short deck R3
Re: Small block W7.8.9 intake any one put on w2/w5??? [Re: RAY1969CARS] #2293781
04/25/17 12:16 PM
04/25/17 12:16 PM
Renton Washington
Renton Washington
Tall deck R3. The intake was supposedly the first ever casting ritter did, so it was blank for bolt holes and such which might of helped this situation.
No parts left, I sold the entire top end for a song about a year ago.
-Dustin
Re: Small block W7.8.9 intake any one put on w2/w5??? [Re: RAY1969CARS] #2293784
04/25/17 12:25 PM
04/25/17 12:25 PM
Dillsburg, PA
mrsmallblock Offline
Dillsburg, PA
W5dart66 had a set of w5 heads that had a 598 intake .... Never ran it.... Sold the heads.... I believe Ryan Johnson built a motor with that heads and intake but not 100% sure.
Howard
Re: Small block W7.8.9 intake any one put on w2/w5??? [Re: mrsmallblock] #2294368
04/26/17 09:31 AM
04/26/17 09:31 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
It's not rocket science, just do it
Jeff Allison has had valley plates made in the past, perhaps contact him.
Records aren't set doing whatever everyone else is doing.
If you're doing it yourself, take the plunge
If you're getting someone to do it for you, get your cheque book out
Alan Jones
Re: Small block W7.8.9 intake any one put on w2/w5??? [Re: LA360] #2300241
05/06/17 06:49 PM
05/06/17 06:49 PM
CA.
CA.
I talk to Ryan from shady Dell he told me the correct intake to put on a set of W5s on a tall deck was a short deck W9 I have an intake for sale Now
