Dakota lights #2291837
04/21/17 11:14 PM
04/21/17 11:14 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Having a weird issue with my 96 Dakota. If i turn on the high beams they are fine for about a minute...then they go out. Sometimes for 2 seconds and come back on....other times its longer. When i go to low beam they come right back on.
I dont have a problem with the low beams and the dash lights stay on
Ive cleaned up all grounds and connectors under the hood . The headlight switch is new.
Anyone had this happen?
Any ideas ?
Re: Dakota lights [Re: 493_DART] #2291852
04/21/17 11:36 PM
04/21/17 11:36 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Are the headlight bulbs OEM or OEM replacements or the high power "bright" aftermarket bulbs? Many of the aftermarket bright lights draw too much current.
There could also be corrosion inside the headlight feed wires, resistance creates heat, and it sounds like the wiring is getting hot.
It may be time to set up the headlights on relays. Gene
Re: Dakota lights [Re: 493_DART] #2291938
04/22/17 02:17 AM
04/22/17 02:17 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
they are factory style bulbs i believe.
ill go see if the wiring is getting hot
Re: Dakota lights [Re: 493_DART] #2292625
04/23/17 11:42 AM
04/23/17 11:42 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Does the high beam use its own relay separate from the low beam? I'd check there too
**Photobucket sucks**
Re: Dakota lights [Re: 493_DART] #2293586
04/25/17 12:19 AM
04/25/17 12:19 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
didnt see a headlight relay..but there is a big fuse
Re: Dakota lights [Re: 493_DART] #2304713
05/15/17 05:05 AM
05/15/17 05:05 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
well...i made my own circuit today because the low beams cut out the other night. Im done chasing wiring on the old truck .
New 30 amp toggle switch with a 30A fuse---runs the low or high beams .
Done---works perfect. None of the wiring gets hot.
