Re: Is it worth it to set the rear shocks straight vertical?
[Re: GY3]
#2291503
04/21/17 12:11 PM
04/21/17 12:11 PM
Thumperdart
State of confusion
Made a hugh difference on my Dart and most of the fastest cars on the planet have em that way for a reason...........
[Re: GY3]
#2291510
04/21/17 12:18 PM
04/21/17 12:18 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Shocks will be most effective when they operate in the same arc as the suspension travel.
[Re: GY3]
#2291532
04/21/17 01:16 PM
04/21/17 01:16 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Yes helped my car a lot, I see no ill effects on the street from making the change. It seems to handle and ride the same, of course I didn't build my car for cornering. I would recommend it.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: GY3]
#2291534
04/21/17 01:18 PM
04/21/17 01:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You have to look at where the "applied load" will be.. a drag car its simple.. but on a road race car its a different applied load.. so number one thing is to figure out what will the car be used for.. then work from there.. I set my Rampage up as a drag/street car but with the drag race part as the primary.. so I put the shocks in vertical and it also has ladder bars with a diagonal link so it doesnt like to go around corners but it does it fine.. with ladder bars the rear end doesnt like to twist in the chassis(very rigid) but works great in a forward motion ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: GY3]
#2291549
04/21/17 01:50 PM
04/21/17 01:50 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Shocks see more vertical load when they are angled. A 30 degree shock will see approximately 15% more load (and need to be 15% stiffer) to act the same way as vertical shock. The further the angle, you're trading vertical stability vs. side to side stability. For what it's worth, Mark Mencer ( http://www.menscermotorsports.com/) told me not to bother going through the trouble to make mine vertical. My car has been a best of 1.38 60ft on 275 radials at 3740lbs with caltracs. If you were building a new car from scratch I would surely make them vertical, but I can tell you mine has been fine on the factory angles down to the mid 9's.
[Re: dizuster]
#2291774
04/21/17 09:00 PM
04/21/17 09:00 PM
Posts: 4,704 Wichita
GY3
Wichita
Shocks see more vertical load when they are angled. A 30 degree shock will see approximately 15% more load (and need to be 15% stiffer) to act the same way as vertical shock. The further the angle, you're trading vertical stability vs. side to side stability. For what it's worth, Mark Mencer ( http://www.menscermotorsports.com/) told me not to bother going through the trouble to make mine vertical. My car has been a best of 1.38 60ft on 275 radials at 3740lbs with caltracs. What shocks do you use? If you were building a new car from scratch I would surely make them vertical, but I can tell you mine has been fine on the factory angles down to the mid 9's.
[Re: dizuster]
#2292079
04/22/17 01:26 PM
04/22/17 01:26 PM
Posts: 22,732 Bitopia
jcc
Bitopia
My thinking is they actually see less load, and they need to be stiffer to effect the smaller load they are seeing at a steeper angle ,to exert the same final amount of overall control? ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: jcc]
#2292585
04/23/17 10:12 AM
04/23/17 10:12 AM
Posts: 19,633 north of coder
moparx
My thinking is they actually see less load, and they need to be stiffer to effect the smaller load they are seeing at a steeper angle ,to exert the same final amount of overall control? according to AFCO, [example] "a 200#/inch spring mounted at a 20* angle gives a 176#/inch rate when figured for ride rate [200x.88]". it goes on to give the multipliers for different mounting angles. mount angle : 0*, 10*, 15*, 20*, 25*, 30* rate multiplier : 0, .97, .93, .88, .82, .75 this is for coilover springs, but i would think it should apply to regular shocks as well. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
