Is it worth it to set the rear shocks straight vertical? #2291370
04/21/17 01:09 AM
04/21/17 01:09 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
...rather than staggered?
It's a street car with Cal-Tracs and split mono leaf springs.
Re: Is it worth it to set the rear shocks straight vertical? [Re: GY3] #2291385
04/21/17 01:36 AM
04/21/17 01:36 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
No, less leverage.
Re: Is it worth it to set the rear shocks straight vertical? [Re: GY3] #2291387
04/21/17 01:36 AM
04/21/17 01:36 AM
If this is a drag only car yes, if street and strip car and you don't want any roll control from the shocks while cornering run them straight up work
Re: Is it worth it to set the rear shocks straight vertical? [Re: GY3] #2291503
04/21/17 12:11 PM
04/21/17 12:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Made a hugh difference on my Dart and most of the fastest cars on the planet have em that way for a reason...........
Re: Is it worth it to set the rear shocks straight vertical? [Re: GY3] #2291510
04/21/17 12:18 PM
04/21/17 12:18 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Shocks will be most effective when they operate in the same arc as the suspension travel.
Re: Is it worth it to set the rear shocks straight vertical? [Re: GY3] #2291516
04/21/17 12:24 PM
04/21/17 12:24 PM
P
Porter67 Offline
Porter67  Offline
P
If your traction on the street is marginal it helps I think, I went from a trace of tire smoke on the launch to just enough wheel spin to get up on things and hook.
Re: Is it worth it to set the rear shocks straight vertical? [Re: GY3] #2291532
04/21/17 01:16 PM
04/21/17 01:16 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yes helped my car a lot, I see no ill effects on the street from making the change. It seems to handle and ride the same, of course I didn't build my car for cornering. I would recommend it.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Is it worth it to set the rear shocks straight vertical? [Re: GY3] #2291534
04/21/17 01:18 PM
04/21/17 01:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You have to look at where the "applied load" will
be.. a drag car its simple.. but on a road race
car its a different applied load.. so number one
thing is to figure out what will the car be used
for.. then work from there.. I set my Rampage up
as a drag/street car but with the drag race part
as the primary.. so I put the shocks in vertical
and it also has ladder bars with a diagonal link
so it doesnt like to go around corners but it does
it fine.. with ladder bars the rear end doesnt like
to twist in the chassis(very rigid) but works great
in a forward motion
wave
Re: Is it worth it to set the rear shocks straight vertical? [Re: GY3] #2291549
04/21/17 01:50 PM
04/21/17 01:50 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Shocks see more vertical load when they are angled. A 30 degree shock will see approximately 15% more load (and need to be 15% stiffer) to act the same way as vertical shock. The further the angle, you're trading vertical stability vs. side to side stability.
For what it's worth, Mark Mencer (http://www.menscermotorsports.com/) told me not to bother going through the trouble to make mine vertical. My car has been a best of 1.38 60ft on 275 radials at 3740lbs with caltracs.
If you were building a new car from scratch I would surely make them vertical, but I can tell you mine has been fine on the factory angles down to the mid 9's.
Re: Is it worth it to set the rear shocks straight vertical? [Re: dizuster] #2291774
04/21/17 09:00 PM
04/21/17 09:00 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
What shocks do you use?
'63 Dodge 330
11.19 @ 121 mph
Re: Is it worth it to set the rear shocks straight vertical? [Re: GY3] #2292017
04/22/17 10:58 AM
04/22/17 10:58 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I have custom valved shocks from Menscer on the rear (Double Adjustable Afco's), and standard (non-custom) double adjustable afco's on the front.
I am an advocate of good shocks. I went from erratic 1.60's to rock solid repeatable low 1.40's with the shock change.
Of course I'm in a situation where I can really overpower the tire, but the shocks alone allowed me to really put a lot more of it to the ground.
Re: Is it worth it to set the rear shocks straight vertical? [Re: dizuster] #2292079
04/22/17 01:26 PM
04/22/17 01:26 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
My thinking is they actually see less load, and they need to be stiffer to effect the smaller load they are seeing at a steeper angle ,to exert the same final amount of overall control? work
Re: Is it worth it to set the rear shocks straight vertical? [Re: jcc] #2292585
04/23/17 10:12 AM
04/23/17 10:12 AM
moparx Online content
moparx  Online Content
according to AFCO, [example] "a 200#/inch spring mounted at a 20* angle gives a 176#/inch rate when figured for ride rate [200x.88]". it goes on to give the multipliers for different mounting angles.
mount angle : 0*, 10*, 15*, 20*, 25*, 30*
rate multiplier : 0, .97, .93, .88, .82, .75
this is for coilover springs, but i would think it should apply to regular shocks as well.
beer
Re: Is it worth it to set the rear shocks straight vertical? [Re: GY3] #2292628
04/23/17 11:44 AM
04/23/17 11:44 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Yeah for sure the steeper the angle the stiffer the shock needs to be to compensate.
