ABS tone ring rusted, can I clean and PAINT? '01 T&C #2290141
04/18/17 05:51 PM
04/18/17 05:51 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
The ABS/Traction control "tone" rings on the front axles are rusted and taking out (wearing) the sensor/pickups. I'm replacing one of the sensors as it threw the code (ABS,BRAKE, Trac Off) and cleaned off the rust on the outer (edge) of the axle tone ring to new clean metal. With all of the winter salt they rust badly and wondering if I can rattle can spray paint the cleaned metal and not affect the function of the ring signal to the sensor? Do I need to keep them to clean metal or can I seal them to minimize them rusting? Thanks in advance.
MikeR
Re: ABS tone ring rusted, can I clean and PAINT? '01 T&C [Re: A12] #2290165
04/18/17 06:55 PM
04/18/17 06:55 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Sorry no help, but I'm interested to see where this goes as I have an '01 and an '07.
No problems yet but would like to be preemptive rather then repairing.
What type of paint are you considering?
We get heavy salt on the roads here too.
I have mechanical Aptitude.
I can screw up anything.
Re: ABS tone ring rusted, can I clean and PAINT? '01 T&C [Re: A12] #2290192
04/18/17 07:50 PM
04/18/17 07:50 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You shouldn't have any problems with rust or paint.
Tone rings are detected magnetically. It should take a VERY long time for them to rust away to the point of failure.
I guess yours are flaking up and contacting the sensors. If that's the case then you could use your favorite rust inhibitor.
- Stu Harmon
Re: ABS tone ring rusted, can I clean and PAINT? '01 T&C [Re: feets] #2290800
04/20/17 12:50 AM
04/20/17 12:50 AM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
I had a 2002 T&C tone rings that were so rusty the axles needed to be replaced. They weren't that much. Wife needed the peace of mind that the antilock brakes would work. I think both the hills and the valleys are important. So if you can't get the spaces clean,too, you still might have a problem.
I looked to see if just the tone rings were available, but I couldn't find any.
Re: ABS tone ring rusted, can I clean and PAINT? '01 T&C [Re: Mr_fixit] #2290902
04/20/17 10:40 AM
04/20/17 10:40 AM
moparx Online content
moparx  Online Content
any time i replace axles on a chrysler FWD, i knock the tone wheels off the axles if they are good, blast 'em, then a fast shot of whatever i have handy in a rattle can. all of the re-man axles i have used come with new tone rings installed [they are plated], so the old ones are not needed for returns. a few taps [be careful] with a brass drift and hammer will remove the old ones. then i have some on hand if needed. several times, i have seen them crack for no apparent reason, such as rust, and i can then replace just the ring without needing the axle. old depression era habits die hard. i learned them from my granpappy.
beer
