Re: ABS tone ring rusted, can I clean and PAINT? '01 T&C
[Re: A12]
#2290165
04/18/17 06:55 PM
04/18/17 06:55 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Sorry no help, but I'm interested to see where this goes as I have an '01 and an '07. No problems yet but would like to be preemptive rather then repairing. What type of paint are you considering? We get heavy salt on the roads here too.
I have mechanical Aptitude. I can screw up anything.
[Re: A12]
#2290192
04/18/17 07:50 PM
04/18/17 07:50 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You shouldn't have any problems with rust or paint.
Tone rings are detected magnetically. It should take a VERY long time for them to rust away to the point of failure.
I guess yours are flaking up and contacting the sensors. If that's the case then you could use your favorite rust inhibitor.
[Re: feets]
#2290800
04/20/17 12:50 AM
04/20/17 12:50 AM
Posts: 1,771 Rustylvania
Mr_fixit
Rustylvania
I had a 2002 T&C tone rings that were so rusty the axles needed to be replaced. They weren't that much. Wife needed the peace of mind that the antilock brakes would work. I think both the hills and the valleys are important. So if you can't get the spaces clean,too, you still might have a problem. I looked to see if just the tone rings were available, but I couldn't find any.
[Re: Mr_fixit]
#2290902
04/20/17 10:40 AM
04/20/17 10:40 AM
Posts: 19,449 north of coder
moparx
any time i replace axles on a chrysler FWD, i knock the tone wheels off the axles if they are good, blast 'em, then a fast shot of whatever i have handy in a rattle can. all of the re-man axles i have used come with new tone rings installed [they are plated], so the old ones are not needed for returns. a few taps [be careful] with a brass drift and hammer will remove the old ones. then i have some on hand if needed. several times, i have seen them crack for no apparent reason, such as rust, and i can then replace just the ring without needing the axle. old depression era habits die hard. i learned them from my granpappy.
