72 Duster Key will not go in ignition switch #2289991
04/18/17 12:36 PM
04/18/17 12:36 PM
Southern Wisconsin
hillsidehemi Offline OP
Southern Wisconsin
Did some searching and found a lot of key stuck in ignition switch but this is the opposite. All of sudden the key will not even go in a quarter of the way. No warning signs just stopped going in. Lucky I was home but I did have to put it on a jack to roll it into the garage because rear and steering were locked up. This is an Automatic on the column car so no linkages involved I don't think. Shot a little lube in the switch but no change. I guess its time to replace the switch? Any other suggestions to check? Thanks in advance.
Re: 72 Duster Key will not go in ignition switch [Re: hillsidehemi] #2290002
04/18/17 01:09 PM
04/18/17 01:09 PM
On The Boat, On The Lake, Wa. ...
amxautox Online content
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Online Content
did you use the proper key? and not your mom's chevy key? work
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: 72 Duster Key will not go in ignition switch [Re: hillsidehemi] #2290064
04/18/17 02:45 PM
04/18/17 02:45 PM
Southern Wisconsin
Southern Wisconsin
Mother long dead. Thanks for the helpful reply and sharing your knowledge.
Re: 72 Duster Key will not go in ignition switch [Re: hillsidehemi] #2290131
04/18/17 05:32 PM
04/18/17 05:32 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
The little barrels fell down into the keyway. Pretty common with the "upside down" key position.
Re: 72 Duster Key will not go in ignition switch [Re: hillsidehemi] #2290136
04/18/17 05:43 PM
04/18/17 05:43 PM
Partridge, KY
Hoop Offline
Hoop  Offline
Partridge, KY
It may can be fixed, if your wondering how, they are a video about Mopar key switch's on youtube.com.
Re: 72 Duster Key will not go in ignition switch [Re: hillsidehemi] #2290186
04/18/17 07:40 PM
04/18/17 07:40 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
Try sticking a wire (unbent paper clip should work) into the key slot and jiggle the pins. If one is stuck that action might free it up to move again.
Re: 72 Duster Key will not go in ignition switch [Re: Powerflow] #2290475
04/19/17 10:34 AM
04/19/17 10:34 AM
Southern Wisconsin
Southern Wisconsin
thanks for the suggestions. Still can't get the key in so it must be time to replace it.
Re: 72 Duster Key will not go in ignition switch [Re: hillsidehemi] #2290539
04/19/17 01:25 PM
04/19/17 01:25 PM
If the lock has the removeable rectangular chrome cover like lock cyls do then you can get in there & clean everything up & some powdered graphite helps (assuming nothing got bent).
Re: 72 Duster Key will not go in ignition switch [Re: hillsidehemi] #2290551
04/19/17 01:43 PM
04/19/17 01:43 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
If the pins have dropped, it may be able to be fixed. Years ago I took mine to a locksmith with the key and he was able to re-pin it. Worked fine ever since and was cheap.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: 72 Duster Key will not go in ignition switch [Re: hillsidehemi] #2290563
04/19/17 02:16 PM
04/19/17 02:16 PM
Southern Wisconsin
Southern Wisconsin
New lock cylinder is $14 so I ordered one. I would never trust this one again anyway. If I had been out somewhere when this happened it would have had to been towed.
Re: 72 Duster Key will not go in ignition switch [Re: hillsidehemi] #2290564
04/19/17 02:17 PM
04/19/17 02:17 PM
Southern Wisconsin
Southern Wisconsin
