Trunk weaterstripping Removal #2290321
04/18/17 11:16 PM
04/18/17 11:16 PM
TX
dart683341 Offline OP
TX
What is best way to remove old trunk weatherstripping from a 1968 dart?
Is their anything I can spray on and use to scrape it off easier without damaging the paint? looks like its on there pretty good. I think I got the install down pretty good,but removal and cleaning looks like the hard part.
Re: Trunk weaterstripping Removal [Re: dart683341] #2290340
04/18/17 11:57 PM
04/18/17 11:57 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Maybe try wax and grease remover? Even if it doesn't work it shouldn't harm the paint.
Re: Trunk weaterstripping Removal [Re: Neil] #2290349
04/19/17 12:07 AM
04/19/17 12:07 AM
TX
TX
Thanks , I thought about a degreaser of some sort and a plastic knife but don't want to mess up paint anywhere.
Re: Trunk weaterstripping Removal [Re: dart683341] #2290376
04/19/17 01:10 AM
04/19/17 01:10 AM
TX
TX
Where is the best place to get the trunk seal?
Re: Trunk weaterstripping Removal [Re: dart683341] #2290378
04/19/17 01:13 AM
04/19/17 01:13 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I used WD40 and a lot of rubbimg.
Re: Trunk weaterstripping Removal [Re: dart683341] #2290380
04/19/17 01:17 AM
04/19/17 01:17 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Contact cement remover would be my first choice as that's what it was likely stuck on with (weatherstrip adhesive). Or try Goo Gone or Goof Off - should not harm paint.
Wax and grease remover is not a solvent per se and likely won't dissolve the glue. Likewise with WD40, there is very little solvent in it since its mainly a water repellent and lubricant.
Re: Trunk weaterstripping Removal [Re: Stanton] #2290386
04/19/17 01:31 AM
04/19/17 01:31 AM
TX
TX
Thanks for the Info , I was afraid it was going to be a lot of labor involved by the looks of it. Trying to make a small neighborhood car show next month, been putting the trunk seal off but want to have the trunk open at this show
Re: Trunk weaterstripping Removal [Re: dart683341] #2290410
04/19/17 02:47 AM
04/19/17 02:47 AM
WA
tman Online content
tman  Online Content
WA
Re: Trunk weaterstripping Removal [Re: dart683341] #2290502
04/19/17 11:26 AM
04/19/17 11:26 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Well I used WD40 and all I can say is it removed all the glue on the paint from the weatherstrip on my charger. It took some rubbing but it all came off with no harm to the paint. Don`t knock it until you try it. I have also used it to remove sticker/decal glue with good success. BTW, Goof Off will harm the paint if you use too much. Ask me how I know.
