Re: 69 Dart disk brake conversion
[Re: Donny]
#2289703
04/17/17 10:15 PM
04/17/17 10:15 PM
RapidRobert
way back (dont remember all the details) but I had a drum LCA that had holes for 1/2" bolts & for my disc app I drilled out the holes to fit the 9/16 bolts (the iron was soft & the bit went thru em like butter) cuz the two were the same exc for the bolt hole ID & there was plenty of meat in the boss(s) so integrity was not compromised. this might have been on an early A app. If any of this helps you.
[Re: meathead66]
#2289926
04/18/17 10:07 AM
04/18/17 10:07 AM
Posts: 141 Ohio, USA
Donny
Ohio, USA
I'm in the process of doing the same thing but I'm using the bolts from the donor kit. But not exactly sure what your asking. Mine for the 69 Dart came from a 73 Duster. Perhaps a picture to see what you're doing? Bolts that attach the spindle to lower ball joint are much too large a diameter to fit the stock lower ball joint. These bolts came with the kit/parts I purchased, I did not receive a new lower ball joint. So my assumption is the lower ball joint that works with this new spindle must be an upgrade or different than stock.
[Re: Donny]
#2289942
04/18/17 11:15 AM
04/18/17 11:15 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Neither an upgrade or non-stock. You just have the wrong stock lower ball joint. You have the small ones, you need the big ones. Pic in the link http://www.bigblockdart.com/techpages/linkage.shtml
[Re: Donny]
#2290261
04/18/17 09:32 PM
04/18/17 09:32 PM
Posts: 5,829 ohio
ruderunner
ohio
Its ok, were just waiting for the "why wont my car stop?" questions...
Angry white pureblood male
[Re: ruderunner]
#2290543
04/19/17 01:32 PM
04/19/17 01:32 PM
Posts: 361 mississippi
lostdog
mississippi
Its ok, were just waiting for the "why wont my car stop?" questions... bwwhahahaha!!! I had this revelation last night.. I have brake woes myself. I bought a budget-build rear disc conversion for my '73 Cuda and what I got was a budget-build rear disc conversion. I am working through this thing with poor instructions and cheap parts, and half-answer help from the vendor telling myself, "it's gonna fit just fine". Then it occurred to me that it may not stop. I'm looking for a new direction or even going with drums.
[Re: lostdog]
#2290548
04/19/17 01:37 PM
04/19/17 01:37 PM
RapidRobert
^ more details please, the guys here can advise/fix anything.
[Re: RapidRobert]
#2290557
04/19/17 01:53 PM
04/19/17 01:53 PM
lostdog
mississippi
^ more details please, the guys here can advise/fix anything. The car didn't have rear brakes - I mean there were no brakes on it. So I ordered this kit and I find a disclaimer at the end of the instruction stating that if I don't consistently use the park brake, the calipers will not adjust. It seems these calipers are modeled after some 70's GM style. On top of that, the calipers wouldn't adjust out enough to allow the rotors to move so basically the brakes are locked up upon installation. I have messed with this longer than is reasonable. I am not new these type projects. I don't have confidence in the product so I'm sending them back if I can. If I could find a good set of 10.5 or 11" 8 3/4 drums I may just go with that unless someone has another suggestion.
[Re: Donny]
#2290589
04/19/17 03:13 PM
04/19/17 03:13 PM
Supercuda
About to go away
About to go away
up yours
You have to screw them in, not use a C clamp A video showing how, kinda long. https://www.youtube.com/watch?v=opjdu8DdVeA
[Re: Supercuda]
#2290591
04/19/17 03:19 PM
04/19/17 03:19 PM
lostdog
mississippi
You have to screw them in, not use a C clamp Yes, I screwed them in until there was no more movement then I went with the clamp thinking maybe it needed to be pushed back off the first detent in the ratchet. I don't know. Maybe I will take another look at it but it seems like it should be easier.
[Re: Supercuda]
#2290616
04/19/17 04:13 PM
04/19/17 04:13 PM
lostdog
mississippi
This video was what I needed to see! Apparently, I need to clock the piston around to be able adjust the throw on the e-brake lever! Thank you ! I can stop cussing now
[Re: Donny]
#2290641
04/19/17 05:32 PM
04/19/17 05:32 PM
Supercuda
About to go away
About to go away
up yours
You are welcome, the aftermarket, for the most part and IMO, sux when it comes to quality instructions.
[Re: Donny]
#2294470
04/26/17 01:02 PM
04/26/17 01:02 PM
Supercuda
About to go away
About to go away
up yours
I have a 65 Cuda I converted to discs up front using stock parts. I am running stock 15x7" cop car rims. Though to be honest I could pull the rims in more (increase backspacing) and have room for more tire.
The stock stuff increases the track about 3/4", I have no idea how much the Right Stuff kit might change the track.
