Masking "PLYMOUTH" 68 GTX? #2289314
04/17/17 11:21 AM
04/17/17 11:21 AM
68gtx Offline OP
68gtx  Offline OP
I had the trunk panel trim plate re-chromed. I will be painting it myself. My question is how should I mask off the letters PLYMOUTH on the panel? I considered tape and a razor but I don't want to scratch the chrome. Any ideas? Thanks Larry J
Re: Masking "PLYMOUTH" 68 GTX? [Re: 68gtx] #2289330
04/17/17 11:57 AM
04/17/17 11:57 AM
Omaha
road Offline
road  Offline
Omaha
Just did mine.
For that step, I put vasoline in the letters, cleaned around the letters and painted argent.
Cleaned vasoline out after painting.
Filled in the black and let dry.
Then lightly wiped the top of the letters off with thinner to expose chrome.
Re: Masking "PLYMOUTH" 68 GTX? [Re: 68gtx] #2289336
04/17/17 12:10 PM
04/17/17 12:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
There is a product called "liquid mask". problem is its likely only sold by the gallon.
You could also use the latest and greatest removable Plastic Dip spray. Spray the letters, trim them and shoot your panel then remove the rest of the plastic dip.
Re: Masking "PLYMOUTH" 68 GTX? [Re: 68gtx] #2289475
04/17/17 03:29 PM
04/17/17 03:29 PM
68gtx Offline OP
68gtx  Offline OP
I have used liquid mask in the past. Vasoline I had considered as well my concern with gasoline was clean up and the lines not being crisp? Thanks for the replies I will post pics when done.
Re: Masking "PLYMOUTH" 68 GTX? [Re: road] #2289554
04/17/17 05:40 PM
04/17/17 05:40 PM
68gtx Offline OP
68gtx  Offline OP
The recess area where the red vinyl stripe goes is that a different color silver and not argent. thanks Larry J
Re: Masking "PLYMOUTH" 68 GTX? [Re: 68gtx] #2289704
04/17/17 10:18 PM
04/17/17 10:18 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Masking frisket is available at any decent art supply store in small bottles.
I tried it once and had average results with it. Just plain tough to obtain a crisp masking line on small scale things.
Re: Masking "PLYMOUTH" 68 GTX? [Re: 68gtx] #2289928
04/18/17 10:15 AM
04/18/17 10:15 AM
btomasko Offline
btomasko  Offline
Hi,I would like to know who refinished your trunk finish panel,looks great also the approximate cost, being here in jersey the cost to have this done is quite high. Thanks
Brian btomasko@yahoo.com
Re: Masking "PLYMOUTH" 68 GTX? [Re: 68gtx] #2289982
04/18/17 12:22 PM
04/18/17 12:22 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Pin striping tape, or else lay out strips of tape on a piece of glass, tile, or some similar hard clean material, and use a ruler and razor/x-acto knife, etc. and cut your own thin masking tape strips.
Re: Masking "PLYMOUTH" 68 GTX? [Re: btomasko] #2290005
04/18/17 01:22 PM
04/18/17 01:22 PM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
X2, I had to "convert" a Sport Satellite tail panel for use on my GTX because my original was so bad.
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
