No inexpensive 10:1 std bore 440 pistons? #2289117
04/16/17 11:23 PM
04/16/17 11:23 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I've been running through all the online catalogs I can find and nobody seems to make an inexpensive 10:1 piston for a standard bore 440.
My block cleaned up nicely at 4.322" and I don't want to punch it without good reason.
I can find them up to 9.5:1 then it jumps to the 10.8:1 KB363 at $640 a set.
I'm running stock rods and Eddy 88cc heads. The cam shows zero overlap on the card and I'm trying to build it into a high torque cruiser for the Imperial.
I get the feeling that even with the aluminum heads the 10.8:1 is going to be too high for most pump gas.
Any suggestions? It's been many years since I've shopped for pistons.
- Stu Harmon
Re: No inexpensive 10:1 std bore 440 pistons? [Re: feets] #2289126
04/16/17 11:35 PM
04/16/17 11:35 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Machine some big valve reliefs in the piston tops. grin
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: No inexpensive 10:1 std bore 440 pistons? [Re: feets] #2289131
04/16/17 11:40 PM
04/16/17 11:40 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Run it at 9.5 and burn crap gas. Chasing half a point of compression on a street cruiser seems like the juice not being worth the squeeze. Or deck the heads .020.
Have you looked at the Icon IC9953? S/F....Ken M
Re: No inexpensive 10:1 std bore 440 pistons? [Re: EchoSixMike] #2289151
04/17/17 12:23 AM
04/17/17 12:23 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
9.5:1 CR with open chambers is perfect for pump gas, Texas heat and a 47,000 lbs. curb weight. It might be a good idea to have the exhaust manifolds coated to keep underhood temps down. Pump gas percolates so easily this is more of a concern than ever, especially with 36 sq. ft. of underhood insulation lol.
Decking the block/heads to get it close to ten might be an option?
You might have the only set of open chamber Edelbrock Mopar heads ever sold?
Re: No inexpensive 10:1 std bore 440 pistons? [Re: feets] #2289157
04/17/17 12:33 AM
04/17/17 12:33 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Did you try 440 Source? Cast, hyper or forged?
I'll assume that 9.5 advertised is for 88cc chambers & close to zero deck, and that those heads are stuff you already have. In which case given the weight & likely gearing & small cam, sounds OK. Might get you into mid-grade fuel instead of premium, or allow more timing.
You might need to deck the block & the heads anyway just to get true surfaces.
But...zero overlap?
Re: No inexpensive 10:1 std bore 440 pistons? [Re: feets] #2289170
04/17/17 12:51 AM
04/17/17 12:51 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
yeah, if you're combustion chamber isn't going to give you a tight quench then 9.5:1 is probably right where you want to be....especially with a little cam.
Re: No inexpensive 10:1 std bore 440 pistons? [Re: feets] #2289171
04/17/17 12:51 AM
04/17/17 12:51 AM
eBay may have something.
Re: No inexpensive 10:1 std bore 440 pistons? [Re: feets] #2289210
04/17/17 01:56 AM
04/17/17 01:56 AM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Advertised CR when it comes to pistons is a crapshoot unless you already know your measured deck height, chamber volume etc.
I'd steer clear of cast/hypereutectic unless I was going .030 over. They run tight piston to wall with those and I suspect that all went out the window with the cleaned up at 4.322 bore.
Summit has the forged L2266F Speed Pro's on for $328.99 in 4.320" with a 1.991 CH.
Don't know how that compares to the stock piston for CH or weight. Do you have balancing in the budget?
How about a set of stock used 440 Magnum pistons cleaned up with new rings?
If you can score a set of those you can check off cheap, bump in CR and no need to balance if you can live with the OEM tolerance.
Kevin
Re: No inexpensive 10:1 std bore 440 pistons? [Re: feets] #2289233
04/17/17 02:50 AM
04/17/17 02:50 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
4.322 is not enough wear to be conserned about for evenstd bore pistons .
running in that heavy car will generate more heat and pistons
ons will swell a little more .
2355 trw will get app .020 deck heigth .
2266 will be not less than .080 in the hole !
my block was decked .012 and my 2266 pistons are .080 down !
Re: No inexpensive 10:1 std bore 440 pistons? [Re: feets] #2289333
04/17/17 12:01 PM
04/17/17 12:01 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Yeah, these are really early Eddy heads.
I've been doing the math, not going by catalogs.
The ICON 9953 gives me 9.37:1.
Speed Pro 2266 gives me 8.49:1 (what I ran in the TT440).
Speed Pro 2355 gives me 9.16:1.
- Stu Harmon
Re: No inexpensive 10:1 std bore 440 pistons? [Re: feets] #2289501
04/17/17 04:13 PM
04/17/17 04:13 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Sell those heads and then get the ones that will get you where you need to be without custom pistons???
If a manufacture has a piston you want, but it's .030, can you try asking if they will make the same piston in the stock diameter? Seems like it wouldn't be that much effort.
What brands have you looked at? Arias, Wiseco, JE, Ross, Mahle???
Re: No inexpensive 10:1 std bore 440 pistons? [Re: Neil] #2289524
04/17/17 04:58 PM
04/17/17 04:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I believe he said INEXPENSIVE.
Feets you have a lathe.
Too tall a CH can be addressed.
Don't be the exception.
Re: No inexpensive 10:1 std bore 440 pistons? [Re: Supercuda] #2289526
04/17/17 05:01 PM
04/17/17 05:01 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Re: No inexpensive 10:1 std bore 440 pistons? [Re: feets] #2289536
04/17/17 05:20 PM
04/17/17 05:20 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
KB237 looks like it might be the ticket and STD is supposed to be available.
Re: No inexpensive 10:1 std bore 440 pistons? [Re: feets] #2289538
04/17/17 05:22 PM
04/17/17 05:22 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Run the ICON 9953 and be happy when you get that batch of crappy fuel. Deck the heads to get more compression, if you want.
For a street car, this is chasing Elvis. You're talking about circa 2.5% power difference in a point of compression. If it's that important, call Diamond and get the bore and CH you need from a 52001 or 52002 shelf piston. Going to be $800+/set. It's your money, your decision. S/F....Ken M
Re: No inexpensive 10:1 std bore 440 pistons? [Re: feets] #2289574
04/17/17 06:19 PM
04/17/17 06:19 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I use the 2355 with eddie heads in my 446. Runs great now for 10 years. Makes my 340 10-1 challenger feel like a slant 6. I came up with 10.2-1 with 2355 and eddie heads on my 440.
No way I would run the LO Po 80 in the hole pistons. When I got my short block that is what was in there. I swapped them out for a set of 2355 when I built my 440 and it runs fine on 91 octane.
Re: No inexpensive 10:1 std bore 440 pistons? [Re: Hugh Jorgan] #2289576
04/17/17 06:20 PM
04/17/17 06:20 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Originally Posted By Hugh Jorgan
I was looking at the 2295 and it showed 10.8:1 with this setup. Milling the tops seems viable.
- Stu Harmon
Re: No inexpensive 10:1 std bore 440 pistons? [Re: feets] #2289845
04/18/17 01:05 AM
04/18/17 01:05 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Have you looked into Wiseco Pro-Tru pistons? They are the best low dollar pistons on the market IMHO twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: No inexpensive 10:1 std bore 440 pistons? [Re: feets] #2289921
04/18/17 09:44 AM
04/18/17 09:44 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Most piston manufacturers will give you one free dimensional change. I had to get a custom diameter set for my 400 and Diamond did it without additional charges.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: No inexpensive 10:1 std bore 440 pistons? [Re: feets] #2290191
04/18/17 07:48 PM
04/18/17 07:48 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I picked up a small piece of polycarbonate and a large medicine syringe from the pet store last night.
As soon as I get the chance (maybe tonight) I'll measure the heads and find the actual combustion chamber volume.
- Stu Harmon
