No inexpensive 10:1 std bore 440 pistons?
#2289117
04/16/17 11:23 PM
04/16/17 11:23 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I've been running through all the online catalogs I can find and nobody seems to make an inexpensive 10:1 piston for a standard bore 440.
My block cleaned up nicely at 4.322" and I don't want to punch it without good reason.
I can find them up to 9.5:1 then it jumps to the 10.8:1 KB363 at $640 a set.
I'm running stock rods and Eddy 88cc heads. The cam shows zero overlap on the card and I'm trying to build it into a high torque cruiser for the Imperial.
I get the feeling that even with the aluminum heads the 10.8:1 is going to be too high for most pump gas.
Any suggestions? It's been many years since I've shopped for pistons.
Re: No inexpensive 10:1 std bore 440 pistons?
[Re: feets]
#2289333
04/17/17 12:01 PM
04/17/17 12:01 PM
feets
Senior Management
Senior Management
Irving, TX
Yeah, these are really early Eddy heads.
I've been doing the math, not going by catalogs.
The ICON 9953 gives me 9.37:1. Speed Pro 2266 gives me 8.49:1 (what I ran in the TT440). Speed Pro 2355 gives me 9.16:1.
[Re: feets]
#2289501
04/17/17 04:13 PM
04/17/17 04:13 PM
Posts: 20,622 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Sell those heads and then get the ones that will get you where you need to be without custom pistons???
If a manufacture has a piston you want, but it's .030, can you try asking if they will make the same piston in the stock diameter? Seems like it wouldn't be that much effort.
What brands have you looked at? Arias, Wiseco, JE, Ross, Mahle???
[Re: Neil]
#2289524
04/17/17 04:58 PM
04/17/17 04:58 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I believe he said INEXPENSIVE. Feets you have a lathe. Too tall a CH can be addressed.
[Re: feets]
#2289536
04/17/17 05:20 PM
04/17/17 05:20 PM
Supercuda
About to go away
About to go away
up yours
KB237 looks like it might be the ticket and STD is supposed to be available.
[Re: feets]
#2289538
04/17/17 05:22 PM
04/17/17 05:22 PM
Posts: 494 IL
EchoSixMike
IL
The ICON 9953 gives me 9.37:1. Speed Pro 2266 gives me 8.49:1 (what I ran in the TT440). Speed Pro 2355 gives me 9.16:1. Run the ICON 9953 and be happy when you get that batch of crappy fuel. Deck the heads to get more compression, if you want. For a street car, this is chasing Elvis. You're talking about circa 2.5% power difference in a point of compression. If it's that important, call Diamond and get the bore and CH you need from a 52001 or 52002 shelf piston. Going to be $800+/set. It's your money, your decision. S/F....Ken M
[Re: Hugh Jorgan]
#2289576
04/17/17 06:20 PM
04/17/17 06:20 PM
feets
Senior Management
Senior Management
Irving, TX
I was looking at the 2295 and it showed 10.8:1 with this setup. Milling the tops seems viable.
[Re: feets]
#2290191
04/18/17 07:48 PM
04/18/17 07:48 PM
feets
Senior Management
Senior Management
Irving, TX
I picked up a small piece of polycarbonate and a large medicine syringe from the pet store last night.
As soon as I get the chance (maybe tonight) I'll measure the heads and find the actual combustion chamber volume.
